2002 Jeep Wj Lengths on UCA Front - JeepForum.com
post #1 of 2 Old 12-12-2013, 08:32 PM Thread Starter
Wjheep
Wj 2002 Jeep Wj Lengths on UCA Front
Hey,
everyone I have a 02 jeep wj with a iron rock 3" lift
-Iron rock 3" springs
-Bilstein 5100 Series Shocks
-Iron Rock Adjustable lower control arms
-Iron Rock Adjustable Track bar
-Iron Rock Extended Rear Sway Bar links
Now what I am looking for is I want to fabricate my own upper fixed control arms and possible a rear spacer for A Arm if anyone has a build thread or might know measurements?
Wjheep is offline
post #2 of 2 Old 12-13-2013, 03:42 PM
Tollmtn
Originally Posted by Wjheep View Post
Hey,
1. What length do you have your lower arms set at now?
2. Is the Jeep tracking OK indicating that you have enough caster?
3. Do you have driveline vibration?
If the answer to question 1 is between 15 7/8" and 16 1/4", the answer to questions 2 is yes and the answer to 3 is no..... Build your UCAs 14.9" long from bolt hole C/L to bolt hole C/L. If your answers are different, I need more information.
Below is a cad drawing by fulljeep off a sketch of mine that I posted of a 2" spacer. The dimensions may not be perfect they were taken off an existing spacer and checked against an OEM ball joint so they should be close enough for you.
If you are making a 2" weldment the 2.312" counter bored hole will not be a concern to you just as long as that area is open. But if you are machining the spacer the counterbore needs to be at least .275" deep. The depth is not critical as long as it is at least that number, it is just clearance for the protrusion on the bottom of the ball joint.
fulljeep if you read this you could correct your front view to reflect this information. I should have provided you with both views in the first place.
Tollmtn is offline
