2002 jeep grand "HI" heated seat amber light replacement? - JeepForum.com
post #1 of 8 Old 11-24-2013, 06:54 PM Thread Starter
02grandy
02grandy's Avatar
Wj 2002 jeep grand "HI" heated seat amber light replacement?
for my heated seats do I have to buy the whole switch or are there replaceable bulbs for the high and low????? just my high is out
02grandy is offline
post #2 of 8 Old 11-24-2013, 07:38 PM
Terminal
Are you sure it's burned out even with the headlights on?
Terminal is offline
post #3 of 8 Old 11-24-2013, 07:51 PM
braddf
Weird. The light on my hi setting went out also along with the heat. Does your heat still work fine?
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #4 of 8 Old 11-24-2013, 08:05 PM
Pedro7
Funny you said this. I just noticed my low light was out on my drivers side. My heat does work fine however.
KCCO
2013 WK2
Pedro7 is offline
post #5 of 8 Old 11-25-2013, 12:09 AM Thread Starter
02grandy
02grandy's Avatar
heat works fine on both sides high and low just the light
02grandy is offline
post #6 of 8 Old 11-25-2013, 12:37 AM
mycreativename
I remember reading that the entire switch assembly has to be replaced to replace the light. I just dealt with mine being out, wasn't worth the pain of replacing the switch.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #7 of 8 Old 11-25-2013, 12:51 AM
Ah673000
Over time all my H and L seat heater lights have burnt out.... Seat heaters work fine ..... Seems to be a common failure of minor significance.
Ah673000 is offline
post #8 of 8 Old 11-25-2013, 03:55 AM
Darnice
Someone posted they are Leds, and bad solder joints. He just took the switch apart and resoldered them
Darnice is offline
