2002 Jeep Cherokee 4.0 strange electrical problem - JeepForum.com
post #1 of 6 Old 04-28-2014, 05:01 PM Thread Starter
bmcoupe1
hi guys, today I bought a jeep Cherokee 4.0 straight 6 lpg, but it has a really strange problem, it tries to cut out and sometimes does, this happens when its stationery or driving it, when it does cut out it sometimes takes a while to start, its an auto as well, when it happens when driving the lights on the dash go out well the cruise control and lpg lights like its been turned off but instantly the car comes back on but the functions have been reset and the management light flickers while its off there is also a clicking from the ignition switch area, I have checked the fault code and it comes up with a p1495 which I have read is leak detention pump solenoid but I read that it shouldn't have an affect on the car.
anyone have a clue thanks
bmcoupe1 is offline
post #2 of 6 Old 04-28-2014, 05:07 PM Thread Starter
bmcoupe1
also when it does it when im driving its like its spluttering if you put your foot down it eventually picks up
bmcoupe1 is offline
post #3 of 6 Old 04-28-2014, 06:24 PM
HVACNY
2013 WK
First thing you should do is make sure your battery,and terminals,and cables are clean of rust and corrosion,and tight.Also make sure your battery is good.It is a very common problem on Jeeps and causes all sorts of issues.Then diagnose each issue one at a time.Someone else can guide you on the code,good luck.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #4 of 6 Old 04-29-2014, 02:38 AM Thread Starter
bmcoupe1
The battery looks quite new, but I will check it out, the earth straps though on the side of the engine look really dirty, where oil has leaked out of the rocker cover the engine is pretty much covered in oil could the earths cause this problem as its intermittent I wouldn't of thought it could,
bmcoupe1 is offline
post #5 of 6 Old 04-29-2014, 02:50 PM Thread Starter
bmcoupe1
so had a look tonight and noticed that when you rock the air box on top of the throttle body it causes wires to touch I think has even with the engine off you can hear clicking and another noise, the box isn't bolted down as it has lpg so on tip of the throttle body is like an injection cylinder which causes the box to be about 3 inch higher so has probably been catching wires rocking about, so now I took the filter out and the big pipe and now it seems to be ok, obviously there is some broken wires that need sorting but least I think I know where they are now.
bmcoupe1 is offline
post #6 of 6 Old 04-30-2014, 04:46 PM
HVACNY
2013 WK
Glad to hear you have a starting point.When you sort through everything dont forget to update the thread.Good luck
HVACNY is offline
