2002 grand cherokee Limited air hardly blowing out of any vents - JeepForum.com
post #1 of 9 Old 11-25-2010, 06:47 PM Thread Starter
Gracie10
Have searched throught several forum posts and have read of similiar problmes but not exactly like this. A/C and heat work fine, blower motor appears to be blowing fine but air is hardly blowing at all out of any of vents.
Also, as the truck heats up the air flow appears to blow just a tiny bit harder out of vents but not much. Its cold here in Northern IN and we need the heat to BLOOOOW.
any help would be greatly appreciated.
thanks all.
Gracie10 is offline
post #2 of 9 Old 11-25-2010, 07:17 PM
theskier74
theskier74 is offline
post #3 of 9 Old 11-25-2010, 08:08 PM
straty1987
check to see what codes you get by following the steps under AZC self-diagnostic mode at Jeep Grand Cherokee WK - Climate controls
straty1987 is offline
post #4 of 9 Old 11-26-2010, 09:42 AM Thread Starter
Gracie10
Thanks guys for the info, I will check for the codes 1st and go from there.
Gracie10 is offline
post #5 of 9 Old 11-26-2010, 07:08 PM Thread Starter
Gracie10
code 52
pulled a code "52" which means "re-circ door travel too large"
no what guys? Do I need the kit to replace door flaps in the box behind the glove box.
Thanks!!
Gracie10 is offline
post #6 of 9 Old 11-26-2010, 07:45 PM
esoxhntr
2008 WK
no it's the recirc door, different then blend doors. it has propably fallen off and is sitting atop the blower motor blocking airflow. i believe you need to take dash apart to fix properly. the workaround is to jam the recirc door in either cabin or outside air mode. you will not be able to switch between the two.
'97 XJ. 4.0. *sold*
'01 WJ. 4.7. *sold*
'08 WK 3.0 CRD. Camping, Towing, Fishing Machine v3.0
esoxhntr is offline
post #7 of 9 Old 11-26-2010, 07:57 PM
Falkon
Here, this will probably fix it... http://www.jeepforum.com/forum/f310/...x-pics-347814/
Falkon is offline
post #8 of 9 Old 11-26-2010, 09:05 PM
straty1987
52 dose not sound like thats whats causing your original posted problem of weak air.
have you checked for anything clogging the vents?
post #9 of 9 Old 12-23-2010, 02:00 AM
DrewDahl
Figure it out?
Gracie, were you able to solve the issue? I'm having the same problem (haven't checked the codes, but your description fits perfectly).
Thanks!
DrewDahl is offline
2002 grand cherokee dtc 300 66trakpak WJ Grand Cherokee Forum 0 11-20-2010 07:48 PM
WJ 2002 Grand Chero Limited 4.7 Rough Idle after Radiator Replacement rmattwill WJ Grand Cherokee Forum 11 09-05-2010 06:57 PM
1999 Grand Cherokee blowing hot air when A/C on astro355 WJ Grand Cherokee Forum 10 08-08-2010 08:04 PM
2002 Grand Cherokee Need Help motodude248 WJ Grand Cherokee Forum 5 07-04-2010 09:12 PM
2002 Grand cherokee trans. mrbell83 WJ Grand Cherokee Forum 9 08-09-2007 11:25 AM
