2002 Grand Cherokee Elec Fan - JeepForum.com
post #1 of 28 Old 03-12-2010, 03:23 PM Thread Starter
chm002
It appears my electric radiator fan is not kicking in. That would explain the rise in temperature when standing still. Other then the fan and fuse itself, what else should I look at? Where is the sensor that tiggers the fan to go on?
chm002 is offline
post #2 of 28 Old 03-12-2010, 04:23 PM
perfectcircle
Don't bother. Those fans burn through expensive relays constantly. Your best bet is to upgrade to a mechanical fan Mechanical fan upgrade. - JeepsUnlimited.com Forums
perfectcircle is offline
post #3 of 28 Old 03-12-2010, 10:32 PM Thread Starter
chm002
Interesting, never thought of mechanical as being an upgrade...but I like it.
chm002 is offline
post #4 of 28 Old 03-12-2010, 10:34 PM Thread Starter
chm002
btw, why was the elec fan not removed in the link you sent me? Won't it make sense to remove it? looks like 2 bolts and wala.
chm002 is offline
post #5 of 28 Old 03-12-2010, 10:43 PM
perfectcircle
You can remove it if you like. I don't remember what he did in the long run. I'm sure it's more than two bolts but you're right, probably isn't too hard to remove.. The mech fan is an upgrade because it'll pretty much never fail you. It'll cool the motor so much better than the efan and you won't have to worry about the e fan. it's highly common for the relays and fan to crap out. A lot of times when they do, they'll leave the fan running after the car is turned off..thus killing your battery! That's what happened to me. I think the relays are about $90 or so at the dealer, and to keep replacing them gets costly especially if you overheat the motor!
post #6 of 28 Old 03-12-2010, 11:00 PM Thread Starter
chm002
ok, I'm sold. I just tried looking up the parts. The clutch is easy to find, the baldes not so much. Maybe I'll call the local Jeep Dealer. Do you have any suggestions / sites?
- Henry
chm002 is offline
post #7 of 28 Old 03-12-2010, 11:14 PM
perfectcircle
Pretty sure when I looked, I only found it at the dealer. I still haven't done this myself. Luckily it's been cold here and I don't drive the jeep much ha.
post #8 of 28 Old 03-13-2010, 12:51 AM
ronsaun
2003 WJ
- Henry
make sure you get some knowledge on the blades. they come in different pitch degrees, no. of blades and even color. blades and pitch can affect your cooling either good or bad depending on your needs.
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #9 of 28 Old 03-13-2010, 09:31 AM Thread Starter
chm002
Guess if I buy the blade from a Jeep dealer it shoul dbe correct...no?
chm002 is offline
post #10 of 28 Old 03-13-2010, 09:55 AM
perfectcircle
Yes, don't listen to him. He really has no idea what he's talking about. And has been known to give out false information. Save the part number, get that part and you'll be 100% fine.
post #11 of 28 Old 03-13-2010, 10:46 AM
Diddy4895
I cut a hole in the plastic underneath the headlight assembly so I have easy access to the fan relay. Also took a trip to the auto parts store and bought a relay with a lifetime warranty from O'Reily's. I have since used my warranty five times and they still honor it to this day. The process is a little tedious, however I don't have to go to the dealership anymore and I am able to keep a back up relay on me at all times.
2000 WJ Laredo
IRO 3", Doetsch, Rubi Rims with 32's
Painted Cladding and Grille
Paul
SOLD!!!
Diddy4895 is offline
post #12 of 28 Old 03-13-2010, 10:50 AM
JForest2
On my 03 GC my fan relay went out.. Jeep only had 14k miles on it when it happened too.. Dealer fixed for free.. I was going to change mine over but at the time the price is what killed me from doing it.. This was back in 04 and they wanted closed to $800 for me to convert it..
I know the early jeeps with the 4.7 had electric and mechanical. My 02 durango was like this... Never worried about the temp rising with that set up.. If you want and have the money keep the electric and get the mechanical and have both..
When my father had his 99 4.7 he had both electric and mechanical.. When he was on the highway cruising and the clutch fan kicked in you could feel there was a good loss in power but it cooled the motor right away....
My 04 had the hydrualic set-up for the fan.. Not sure why they went from a clutch fan to this set-up.. Does anybody know why...
James
JForest2 is offline
post #13 of 28 Old 03-13-2010, 11:55 AM Thread Starter
chm002
Just called O'Reily's, they have a clutch and blade. Under $100. Apparently the blade is reversible and has a 19" diameter. Called the local Jeep dealer and they have nothing to sell me for the conversion, can only replace original parts. $200 to have them replace the relay. Hearing all your stories I should be lucky I got 102k miles out of my relay!
Thnak you all for your excellent information. I'll get back to you all when I finsih the conversion....
chm002 is offline
post #14 of 28 Old 03-13-2010, 12:10 PM
perfectcircle
Yeah you don't need to tell them you're converting/adding anything. You NEED the Mopar fan blade. No other fan will move proper air flow. Give the dealer the part number, tell them that's what you want, and ask em how much
post #15 of 28 Old 03-13-2010, 12:20 PM Thread Starter
chm002
oh oh, did not realize that. I asked them if they had any of the blades in stock...their answer was no.
chm002 is offline
Oil leak on 2002 Grand Cherokee Mike D ZJ Grand Cherokee Forum 2 01-29-2010 02:13 PM
2002 2.7td Grand Cherokee(uk) bazzer12 ZJ Grand Cherokee Forum 11 07-11-2008 05:55 PM
2002 grand cherokee headlight 2002jeep ZJ Grand Cherokee Forum 3 12-05-2007 08:46 AM
What does my 2002 grand cherokee have? Edward777 ZJ Grand Cherokee Forum 8 09-23-2007 12:51 AM
2002 Grand Cherokee Hell Raiser 106 ZJ Grand Cherokee Forum 4 12-06-2005 09:42 AM
