2002 Grand Cherokee 9.4 miles per gallon. Need Help!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2002 Grand Cherokee 9.4 miles per gallon. Need Help!!!
2003-2004 Jeep Grand Cherokee Headlight Dark Background wiOPTIC ARMOR WINDOWS all sale now !!!!!!!!1999-2004 Jeep Grand Cherokee Wheel Bearing & Hub Asse
Unread 03-11-2012, 09:21 PM   #1
JeepFuel2002
Recently bought a 2002 Grand Cherokee Laredo with 117,000 miles. 4.0 L Straight 6 cylinders. My problem is that it is spending too much gas. It averages between 9.3 and 9.7 mpg and I'm not pushing it hard. Any ideas, advice on what could be wrong with it?
JeepFuel2002 is offline   Reply With Quote
Unread 03-11-2012, 10:26 PM   #2
S8NNG8
1995 XJ Cherokee
I have a '95 XJ, but I have the same engine, kind of. Anyway, I just replaced my plugs, wires, and dist. cap for $75 & gained about 5 mpg. You may have many issues, but this could be one of them.
D3<!L!>3D
S8NNG8 is offline   Reply With Quote
Unread 03-12-2012, 07:34 AM   #3
JeepFuel2002
I just replaced the plugs. I'm going to replaced the wires, etc and see if that works for me. Thanks for responding. Will keep posting if anything.
Unread 03-12-2012, 10:36 AM   #4
duanewhatley
No plug wires, each plug has its own coil.
duanewhatley is offline   Reply With Quote
Unread 03-12-2012, 10:38 AM   #5
ChrisHager
ChrisHager's Avatar
Change the fluids/filters.
Fuel filter may be clogged up - slap a new one on.
Champion copper plugs work best. What type did you use?
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is online now   Reply With Quote
Unread 03-12-2012, 10:39 AM   #6
Merc1973
Try Fuel filter, air filter, trans fluid level?
Get some Chevron Techron injector cleaner before the fuel filter change.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline   Reply With Quote
Unread 03-12-2012, 02:42 PM   #7
JeepFuel2002
The plugs that I used were champion and yeah there's no wires (coils). I'm going to use the fuel injector cleaner, probably change the coils; the only thin is that I don't have a misfire or check engine light. And I'm going to replace the fuel filter
Unread 03-12-2012, 02:45 PM   #8
JeepFuel2002
By the way the air filter is clean. Transmission fluid level is also good. And once again thank you for all the help.
Unread 03-12-2012, 05:59 PM   #9
billzcat1
Chicken in a Turkey Suit
2003 WJ
Do you have any brakes dragging? What type of driving? Short trips? Hills? Highway/City? Probably needs O2 sensors at 117k if they are still original.
billzcat1 is offline   Reply With Quote
Unread 03-13-2012, 11:59 AM   #10
specia1k
Champion Copper Plugs, WIX Fuel Filter, Throttle Body Cleaner, Seafoam in fuel to clean injectors, Air pressure 33-35lbs (I prefer 35) in tires, Air Filter, Oxygen Sensors (even if there not throwing a code). Is your engine getting up to temperature? Reason I asked, our '02 had a thermostat that was stuck in the open position. So it never got to optimal operating temperature. So the PCM sends more fuel to the engine, to get the temp up, but with open thermostat, it's constantly cooling the engine, while the PCM sends more fuel, i.e. poor mileage. When I looked at the thermostat, stuck wide open. Changed it and MPG jumped back to 18-20 mpg. Was in low teens prior.
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline   Reply With Quote
Unread 03-13-2012, 12:24 PM   #11
1AAdam
i have to do a few of the things mentioned above. alignment and stuff u would want to check too but that wouldn't cause that kind of mileage.
Adam
1aauto.com
888-844-3393
1AAdam is offline   Reply With Quote
Unread 03-13-2012, 02:33 PM   #12
AGDubyaJ
is your check engine light on?
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline   Reply With Quote
Unread 03-13-2012, 04:04 PM   #13
porrsher
1994 ZJ
unhitch that travel trailer you are pulling!
Good lawwwrd! 9 mpg? I get 12 towing at 60 and I thought I was in trouble!
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline   Reply With Quote
Unread 03-13-2012, 04:18 PM   #14
JeepFuel2002
I'm going to get my coils. Now the engine started shaking as if it has a misfire when I start the car and then goes away in few seconds.
Unread 03-13-2012, 04:30 PM   #15
SkipStr
That could be your fuel rail losing pressure . May be a bad check valve in the fuel pump. See if you can borrow a fuel pressure gauge and see if the pressure at the rail drops when the jeep is not running.
SkipStr is offline   Reply With Quote
