2002 grand cherokee 4.0 cam/cam sensor adjustment cause problems? - JeepForum.com
post #1 of 5 Old 05-02-2013, 09:40 AM Thread Starter
02grandy
Wj 2002 grand cherokee 4.0 cam/cam sensor adjustment cause problems?
so i had a problem where my IAC motor was bad but im still having a problem with my idle being high after starting it . so i have to bring it back to those retards. the tech had his machine on my jeep and said the cam sensor or cam was " OFF" so he " ADJUSTED" it. would that now have the components related to the cam be hitting in different spots possibly throwing things off from worn in parts making the engine louder?????
02grandy is offline
post #2 of 5 Old 05-02-2013, 10:34 AM
ChrisHager
Administrator
ChrisHager's Avatar
Was the 'tech' at a jeep dealer? If not, the only way he could have accurately adjusted the cam sensor was with a DRBIII tool which is extremely expensive.
Adjusting the CPS won't cause anything to 'hit' another part. It adjusts your fuel trim and will make it run horribly/not at all if it's adjusted too far out.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 5 Old 05-02-2013, 10:33 PM Thread Starter
02grandy
no it was at the jeep dealer he was fixing my IAC motor and also did that for free yes with the drbIII machine
02grandy is offline
post #4 of 5 Old 05-03-2013, 07:17 AM
ChrisHager
Administrator
ChrisHager's Avatar
If he used the DRBIII machine, you should be good. Look into replacing the TPS and cleaning the throttle body while you're at it.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 5 Old 05-03-2013, 07:45 PM Thread Starter
02grandy
replace tps 2 years ago. bad already?????
02grandy is offline
