2001 WJ looking to buy, need advice - JeepForum.com
post #1 of 4 Old 11-07-2013, 03:46 PM Thread Starter
eric12
I'm Looking to buy this 2001 Jeep Grand Cherokee Laredo with 101,500 miles on it for about 3,200 (Great interior and exterior cosmetics). I took it to a Jeep Dealer to get it checked out before purchasing. Here are a couple of finds
http://jerseyshore.craigslist.org/cto/4171663701.html
Rear Diff/or Rear Wheel Bearing noise?
estimate: $1100
Valve Cover Gasket Leaking
estimate: $400
Front Crank Seal Leaking
estimate: $400
Muffler coming apart
estimate: $800
Is the Car worth the purchase at 3200? Or am I getting myself in to a lot of work?
eric12 is offline
post #2 of 4 Old 11-08-2013, 10:15 PM
gotjeepzj
Get second opinion for everything. Do you have mechanical skills? Changing the valve cover gasket isn't hard so that saves $400.
$800 for a muffler coming apart?!
I paid $400 for a complete header back custom exhaust with new cat and flomaster.
If the rear end checked out, id say yes.
gotjeepzj is offline
post #3 of 4 Old 11-09-2013, 07:12 AM
Cirruslydakota
Lol, $400 for a leaking valve cover on an 4.0?! The fel-pro gasket is $20 and can be changed in under a half hour. You should ask that guy how that "V-6" has worked for him.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #4 of 4 Old 11-09-2013, 09:35 AM
2ndhandWJman
Well, if you add up all of the quoted repairs plus the cost of the vehicle, you come up with $5900. So ask yourself this question: is this jeep worth that amount to you or could you spend that same amount and find a much nicer example of a WJ?
2ndhandWJman is offline
