2001 WJ Brake and ABS Lights Coming On! Please Help! - JeepForum.com
post #1 of 7 Old 05-09-2010, 04:59 AM Thread Starter
HondaPeople
Recently my ABS and Brake light have been coming on my dash board. Is there a sensor going out or something? Any information would be appreciated. Thank you!
2011 Dodge RAM 1500-HEMI, 2001 WJ Laredo-V8
2008 Honda Recon ES 4x4, 2006 Honda Lawn Mower, 2001 Honda VFR800
HondaPeople is offline
post #2 of 7 Old 05-09-2010, 09:05 AM
DirtyThoughts
It's either the speed sensor that is on the transmission, which is about 17 bucks. Or it's one of the ABS sensors on one of the wheels. Do you have a speedometer still?
DirtyThoughts is offline
post #3 of 7 Old 05-09-2010, 09:01 PM Thread Starter
HondaPeople
Yes, I do still have the speedometer. If the sensor goes out, then will i lose the speedometer? Thank you again for your time.
post #4 of 7 Old 05-09-2010, 09:11 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Speedometer is based on the tone rings on the abs system on the WJs.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #5 of 7 Old 05-09-2010, 09:59 PM
StrokedWJ
StrokedWJ's Avatar
The lights are caused by a malfunctioning/missing ABS sensor. Have you had any recent work done to the jeep? Its possible that one of the sensors is broken or the wire going to it was cut.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #6 of 7 Old 05-10-2010, 07:29 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
There is no speed sensor on the transmission. The speed is gathered from information from each abs sensor (one at each wheel) If one fails, it will trip both the abs and brake lights, but the speedo will still work based on info from the other three sensors.
Dirty, if your transmission does have a speed sensor on it, refer to my comments in your other thread regarding your steering setup.
~James
ezflip is offline
post #7 of 7 Old 05-10-2010, 09:25 PM
indept
My WJ's ABS light came on 2 1/2 years ago (1 month before inspection was due). Of course you can't read ABS codes with an OBDII reader so I went to the stealership & paid 45 bucks to read them. It came up that 2 wheel sensors codes & a code for the pump controller (or just pump, I don't remember exactly now). So I tried to check them with an ohmmeter but found you can't check these that way. Well I checked the sensors to verify no busted wires. I seated the big wire harness connector on the pump controller. The light went out and didn't come on again until last week. The antilock brakes worked fine for the whole time, especially during our snowy winter. When the light came on last week on my way to work, I went into work and when I drove home that night it had gone out. well the next day it came on again. When I left work that night (thursday) I pushed on the connector to seat it. The light hasn't come on since. I'm wondering if it's not bad solder joints on the controller board where the mating connector solders to it. I may see if I can get to it without compltely removing it from the Jeep.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
Repaired leaking brake power booster, but now brake lights are on all the time MNWJ ZJ Grand Cherokee Forum 2 05-11-2009 08:59 AM
2001 WJ with Possesed Lights Ruppel ZJ Grand Cherokee Forum 9 10-03-2006 11:13 PM
Interior lights coming on at random leoorl ZJ Grand Cherokee Forum 1 02-19-2006 03:51 PM
Brake squeak? Where’s it coming from? Stuart ZJ Grand Cherokee Forum 5 07-17-2005 05:14 PM
Lights coming on intermittently Waddell ZJ Grand Cherokee Forum 3 09-19-2004 07:22 AM
