2001 Jeep Grand Cherokee V8 oil leak - JeepForum.com
post #1 of 17 Old 03-30-2012, 11:35 AM Thread Starter
Bake1tEazy
Wj 2001 Jeep Grand Cherokee V8 oil leak
Hello everyone! I am new to the forum and I apologize if I placed this in the wrong section... looks like the proper one though
2001 Jeep Grand Cherokee Limited 4.7L V8 is leaking oil just above the oil filter. Is it possible that it's the oil pressure sending unit? If not, what else could it be?
Bake1tEazy is offline
post #2 of 17 Old 03-30-2012, 12:21 PM
HVACNY
2013 WK
Its definitly possible.Mine leaked oil from there,but not really on the floor,more inside the plug area of the sending unit.But its most likely that.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #3 of 17 Old 03-30-2012, 12:32 PM
Dusk53
Mine leaked from the oil filter... Twas the oil filter
edit, noticed you said it was ABOVE the oil filter. probably oil pressure sending unit.
Mah build
East Carolina University
Dusk53 is offline
post #4 of 17 Old 03-30-2012, 04:40 PM
jeepster250
people told me i am wrong but i only been a mechanic for a year... same problem on my jeep right above the oil filter.. it was the oil pressure switch leaking. still worked fine but leaked replace it with a mopar one from the stealer for 67 bucks. BOOM leaks gone. maybe i had a special jeep that leaked from that switch
jeepster250 is offline
post #5 of 17 Old 03-30-2012, 04:54 PM
thunderdan2000
I need to check mine. I have had to add oil since I bought it a month ago and I don't seem to be burning oil. I have to many oil spots in my driveway to notice new ones.
thunderdan2000 is offline
post #6 of 17 Old 03-31-2012, 04:19 AM
MWF
Mine does it, seems a pretty common fault. Got a replacement sensor but looks a hassle to fit due to location.
MWF is offline
post #7 of 17 Old 03-31-2012, 04:29 AM
9toewj
Oil pressure sensor is most likely the culprit..... Changed the oil twice one day because I thought I had a faulty oil filter.... Needless to say it wasn't the filter leaking, and my OPG ended up acting all crazy... Needle floated all over the place.
_____________________________
01 WJ 2.5 Rusty's kit, control arms, etc.
08 Frontier Crew
10 KTM 250xc-w
9toewj is offline
post #8 of 17 Old 03-31-2012, 02:17 PM Thread Starter
Bake1tEazy
My needle is fine and then just randomly drops and reads that there is no pressure. I found a video on how to replace it, looks pretty easy. Thanks everyone!
post #9 of 17 Old 03-31-2012, 03:33 PM
HVACNY
2013 WK
It is easy,just make sure you slide the red clip to unlock the plug before you pull it out.
HVACNY is offline
post #10 of 17 Old 04-01-2012, 03:35 AM
MWF
You got a link to the vid?
MWF is offline
post #11 of 17 Old 04-27-2012, 10:58 AM Thread Starter
Bake1tEazy
My friend emailed it to me and now I can't seem to find it. I can post pics of how to find/remove it. Only took me an extra 5 minutes on top of my oil change. Oh and sorry for not responding sooner. School is keeping me very busy
post #12 of 17 Old 04-27-2012, 01:41 PM
joze
Mine does it too. I'm changing the unit when I'll be changing the oil, because it seems to be a lot more accessible when the oil filter isn't mounted.
Originally Posted by Ljohn221 View Post
You can't start a new civilization without jeeps
Originally Posted by dukie564 View Post
Epic boobs saving threads since 1978
joze is offline
post #13 of 17 Old 04-27-2012, 05:09 PM
jeepster250
dont mean to hi jack. i had the same leak replaced my oil pressure switch. still leaks oil but no where near as much. i cleaned it really good with brake cleaner and checked it a few weeks after i replaced the sensor and i still got some oil dripping and come off my oil filter. oil filter is tight. any suggestions ?
post #14 of 17 Old 04-27-2012, 05:15 PM
HVACNY
2013 WK
I carefully put teflon dope,not tape, on the threads,carefully without getting any in the engine block,and not to much to make it run,and i have no oil dripping anymore.Let it set for 30 minutes before running the Jeep.
HVACNY is offline
post #15 of 17 Old 04-27-2012, 06:28 PM
jeepster250
I don't think its comin from the new switch somewhere else not sure
2001 4.0l WJ Grand Cherokee persistant Oil Leak murkyhorse WJ Grand Cherokee Forum 4 12-19-2011 06:59 AM
2001 Jeep Grand Cherokee BigBoy018 WJ Grand Cherokee Forum 0 10-10-2011 05:43 PM
2001 Jeep Grand Cherokee Coolant Leak rocponee WJ Grand Cherokee Forum 18 09-21-2011 06:13 AM
2001 Jeep grand cherokee laredo 4.0l exhuast 87blkcherokee WJ Grand Cherokee Forum 1 07-26-2011 09:27 AM
2001 Jeep Grand Cherokee A/C issues wags22 WJ Grand Cherokee Forum 7 06-09-2011 06:47 AM
