2001 Grand Cherokee 4wd problem - JeepForum.com
post #1 of 5 Old 11-02-2011, 09:13 PM Thread Starter
jas61199
I have the above mentioned Jeep and I'm having trouble getting it out of 4wd. Going in and staying in is fine. It used to be that if I drove backwards for about 10-15 feet it would disengage. Now that doesn't work. Any ideas? Thanks
jas61199 is offline
post #2 of 5 Old 11-02-2011, 10:29 PM
Sohcvtec1995
change your fluid in the x case
Sohcvtec1995 is offline
post #3 of 5 Old 11-02-2011, 11:39 PM
-SS454-
i too have issues with my 01 select trac coming out of 4x4. It's especially horrible on grippier surfaces and i sometimes have to stop and turn the vehicle off for it to come out of 4wd. I have changed the fluid, but didnt make a diff.
-SS454- is offline
post #4 of 5 Old 11-03-2011, 12:25 PM
ironmatt85
2003 WJ
Make sure you drain, "flush" with fresh ATF+4, then fill... make sure your tires have correct psi in them and that they're balanced, that can definitely make a difference. If not those, the linkage cables may need adjusting if the those things don't do much.
ironmatt85 is offline
post #5 of 5 Old 11-03-2011, 03:34 PM
epGTO
I read on a jeep site that any kind of torque/pressure on the transfer case can cause it not to shift out of 4wd. I have this problem but it's from bad wear on my tires that I need to replace. Different tire pressures, tire sizes (from wear or other), and other factors can cause this. It takes me a few tires in reverse to get out of 4wd but I always eventually get out.
epGTO is offline
Will a 96 grand cherokee motor work in a 2001 grand cherokee with out major issues? blacksslumina WJ Grand Cherokee Forum 4 09-01-2011 11:56 AM
2001 Jeep Grand Cherokee Possible Oil Pump Problem? rocponee WJ Grand Cherokee Forum 4 07-05-2011 12:00 PM
I need HELP with my 2001 Grand Cherokee!!! Brittnie WJ Grand Cherokee Forum 4 07-21-2010 10:07 AM
Looking to buy a 2001 Grand Cherokee 4x4 SHUG WJ Grand Cherokee Forum 2 05-14-2010 06:47 PM
Problem with bleeding brakes for 2001 Jeep Grand Cherokee TeknoJeep WJ Grand Cherokee Forum 2 06-09-2004 04:26 PM
