2000 wj questions - JeepForum.com
post #1 of 5 Old 07-09-2013, 08:28 AM Thread Starter
mjcanham
2000 wj questions
My friend has a 2000 wj and it runs fine for a couple days and then dies while driving and the gauges all stay in the same place. It also won't start back up unless it sits for about a day. Its not throwing out any codes or anything. Anyone know what this can be?
mjcanham is offline
post #2 of 5 Old 07-09-2013, 08:40 AM
4Tom
Removed both battery terminals and clean with sand paper / wire brush. Clean battery poles too. Refit terminals making sure it is good tight connection. Do this first before digging deeper.
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 5 Old 07-09-2013, 08:59 AM Thread Starter
mjcanham
It has a brand new battery and my friend did that stuff to. Have any other ideas. If not thank you for the help
mjcanham is offline
post #4 of 5 Old 07-09-2013, 09:52 AM
4Tom
It sounds very much like a electrical fault and many have said they checked connections only to find out one is lose or corroded. If you get a chance have a look your self.
After battery terminals check ground to body and engine and positive wire for poor connection.
When you say it wont start for a day does it turn over and try to start but won't run or does the starting motor fail to turn ?
WJ 2001 3.1TD
Tom
4Tom is offline
post #5 of 5 Old 07-09-2013, 10:14 AM Thread Starter
mjcanham
Were going to his house on lunch break I'll get more info after I check it out for myself
mjcanham is offline
