Quantcast 2000 WJ 4.5L Stroker Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2000 WJ 4.5L Stroker Build
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 02-01-2009, 02:22 PM   #1
StrokedWJ
Some of you may have already seen this on MC or NAGCA but I figured I'd post it here too. I think I may be the only one running this 4.5L Stroker in a WJ at the moment
Build:
This thread will document our rebuild of my 2000 Jeep WJ's engine. It had ~140k on the clock when the annoying "tick" turned into something a lot worse!
I was already over at a friend's shop, getting my LA's repaired and had him take a listen. We knew it was bad, so he dropped the pan to take a look. He found about 1/5 of the #4 piston in the bottom of the oil pan. The picture makes it look a lot worse than it ended up being. Amazingly there was no damage to the cylinder wall!
So I decided since I needed to replace the piston, might as well upgrade while we're in there. Plan is to go with a 4.5L Simple Stroker from Dino Saava's 4.0 performance site. I modified it a little bit b/c the 677cp pistons were hard to find. Most of the work was done in Chris's shop. I had some help from a member of jeepstrokers.com and the local Carquest Machine shop.
Specs:
* Jeep 4.2L 3.895" stroke crank
* Jeep 4.2L 5.875" rods
* Sealed Power H802CP standard bore pistons (dished to 18cc's)
* 9.20:1 SCR
* 7.96:1 DCR
* Stock 4.0 camshaft
* Port & Polish cylinder head
* Mopar/Victor 0.043" head gasket
* 0.081" quench height
* stock injectors with stock 49psi FPR for '96 and later engines
* 247hp @ 4900rpm, 300lbft @ 3500rpm (thats what Dino's site says)
I also decided to bore the TB out to 62mm and replace the exhaust with a Magnaflow.
The teardown pics...
Engine out (it was a real PITA to get it out with 5" of lift and the ARB on the front):
Getting ready for the stand, but didn't have the correct bolts
We got it on the stand the following day and torn down.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Old 02-01-2009, 02:22 PM   #2
StrokedWJ
the parts:
H802CP standard bore pistons, dished to 18cc
OEM throttle body bored to 62mm
Hot tanked & Sandblasted head
Victor Reinz Gasket Set, Melling oil pump, Piston rings, Cloyes Timing chain, Clevite Main bearings, AMC 258 Rods
Magnaflow 12586 2.5" muffler 5"x11"x22"
The head will go in for the port and polish and I'll have the machine shop install the pistons on the rods Monday. Hopefully we'll have her up and running sometime next week!
Also in but not pictured are the 4.2L crank, rod bearings, and hi-flow cat.
I had all of this typed up as it was ordered, but my laptop HD crashed, so this is all typed from memory/receipts I had laying in front of me. Parts list:
Old 02-01-2009, 02:23 PM   #3
StrokedWJ
we got the bottom end rebuilt. With the pistons installed I measured a average deck clearance of .042", which, with the .038" compressed gasket height gives me SCR of 9.19:1 with a quench of .080". I wasn't thrilled about the high quench height, but its better than the numbers in Dino's recipe so we'll see how it works out.
Old 02-01-2009, 02:24 PM   #4
StrokedWJ
We finished up the installation today! The 4.5L started right up on the first try. The motor acted like it hadn't even been out of the jeep. Both Chris and I were pretty amazed. We'll backtrack a bit to get caught up with the pics.
Ported
Painted up
Re-installation
FINALLY DONE!
Its working great. We let it idle for a while, then changed the oil. Took it for a 10 minute test drive and everything looks good. I had 87 octane in the tank and we didn't notice any pinging, but I'm planning to run mid-grade while gas is so low!
Still need to get my exhaust installed, its too quiet right now...
Old 02-01-2009, 02:27 PM   #5
StrokedWJ
10 straight hours of teardown + 3AM =
That version wasn't nearly powerful enough!
Old 02-01-2009, 02:29 PM   #6
Ridin' Around
Wanna Go Along?
Ridin' Around's Avatar
Ridin' Around is offline   Reply With Quote
Old 02-01-2009, 04:55 PM   #7
cmonson
did you do a cam change at all? You mentioned letting it idle for a little while...
I hope you broke in the cam to the lifters if they are new!!!
cmonson is offline   Reply With Quote
Old 02-01-2009, 05:02 PM   #8
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
Said he used the stock cam.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Old 02-01-2009, 05:02 PM   #9
Jones
Infowars.com
Jones's Avatar
Very nice work, how are the performance gains?
What is it about Ron Paul?
Jones is offline   Reply With Quote
Old 02-01-2009, 05:12 PM   #10
StrokedWJ
Yeah, I reused the stock cam and lifters.
So far I can definitely tell theres a power increase. After giving it a little while to break in and the bank act. recover enough to have my exhaust installed, I'm gonna take it over to the local dyno and see what kinda numbers its really making. I think it'd be good to document b/c this was a fairly low budget build. I wanna see what kind of power increase we're looking at vs. dollars spent.
Old 02-01-2009, 08:43 PM   #11
squashman702
Mongo-fabbed
squashman702's Avatar
Mind doing a price breakdown?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is online now   Reply With Quote
Old 02-01-2009, 09:05 PM   #12
xJoshxx
xJoshxx's Avatar
2011 WK
i too have the 00 wj is the ECM/PCM giving u any problems or hickups?
i would like to do this to my I6 plus u didnt have to have the block bored did u? just bigger pistons rods and all teh other junk pretty much bolt on.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Old 02-01-2009, 09:58 PM   #13
StrokedWJ
Its in my post...
Josh, no problems with the stock computers. According to the scan tool, it ran a little lean for the first little bit then it started adding a little extra fuel to compensate. And you're right no overbore just had it re-honed. The 4.2L connecting rods are actually shorter. Its the increased stroke from the 4.2L crank that makes the difference.
Old 02-02-2009, 12:22 AM   #14
SET2JET
nice write up very informative
SET2JET is offline   Reply With Quote
Old 02-02-2009, 01:16 AM   #15
Bama_WJ
Bama_WJ's Avatar
Very nice. I plan on doing this as soon as my 4.0 takes a dump. Hopefully not any time soon though!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Bone stock and 37 MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers and more to come...
YouTube. - My Video Channel
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- Clayton 6" Springs
- Bilstein 5100 Series Shocks (6" lift)
For Sale Later (once I get my swap done):
- Brand New WJ JKS Track Bar
- Stock WJ Suspension Components
- KOR 2.5" BB Lift
- Many WJ Drivetrain Components (PM for details)
Bama_WJ is offline   Reply With Quote
Glock Forum
