2000 Jeep grand Cherokee stalling - JeepForum.com
post #1 of 21 Old 05-31-2009, 04:20 PM Thread Starter
gregsbabe1
I have a 2000 Jeep grand Cherokee Limited 4x4 v8 that has been stalling. Doesn't matter if i am driving or at a light, it dies. I have replaced the Crank Shaft sensor, Cam shaft sensor and the air idle control valve all of which the mechanic said was the problem, still stalling sometimes it will start right back up and other times it takes 10 tries. Any ideas!!!
gregsbabe1 is offline
post #2 of 21 Old 05-31-2009, 06:15 PM Thread Starter
gregsbabe1
anyone?????
post #3 of 21 Old 05-31-2009, 06:29 PM
4jeepers
Try to check your fuel filters or filter which can clog with debris while the engine is running, sometimes the filter will clog while under pressure and clear when the fuel pump is off. I know this may be a long shot, however this happened to me once a long time ago and that is what made me think of it! GOOD LUCK!!
4jeepers is offline
post #4 of 21 Old 05-31-2009, 07:46 PM
00RedWJ
2006 WK
Any codes? You need to put a pressure tester on the fuel rail to determine if the fuel pump is pushing out the correct pressure. That's another trouble spot on these trucks. I had the same symptoms but it did throw a code and turn out to be the camshaft position sensor
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #5 of 21 Old 06-01-2009, 07:37 AM Thread Starter
gregsbabe1
No codes, the only code we ever had was for the crack sensor which we replaced and still have the issues. I have not checked the fuel pump or pressure though. We were driving on Sunday and it died at a light, took five minutes to restart and dies again after we started moving again, then started right up.
post #6 of 21 Old 06-01-2009, 07:45 AM
Double E
Double E's Avatar
Sounds like the issue a few others have had where the PCM has issues with various solders inside the box. Look through these threads (a few pages deep), or do a search for a write up on what has been found on this topic.
Unfortunately, a replacement is not always the cure as it can have th esame intermittent issues.
Has your jeep been ridden hard on a trail or rocks enough to "jar" the vehicle and loosen up things? I'm wondering what factors can contribute to the PCM issues showing up.... Does it happen at any time or once warmed up? Cold day or hot day? When exactly did this issue first appear and wehat took place just before it that was out of the norm for you or the vehicle? Deep freeze...or super hot day?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 21 Old 06-01-2009, 07:57 AM Thread Starter
gregsbabe1
It is only when we have been driving around, it is warmed up. when it first started i would be driving and it would seem like it stalled but all I had to do was pump the gas a few times and it would resume. Now it full out dies. We only have 75000 miles on it and it is a 2000. never been used for anything but road, it has been babied. we had 76 yesterday and it stalled, and it has stalled in 60 degrees as well. We did the PCM screw fix and still stalls. If it is the PCm, how much does that run and do you have to have it programmed at the dealership? I hate to put tons of money in it ( which I do not have) and have it keep stalling. I have already put in $600.
post #8 of 21 Old 06-01-2009, 02:02 PM
gmp211
Cycle your key in the ignition 5 times (on-off-on-off-on) and it may give you an error code. Look up the code and there ya go. If you have a digital odometer.
Also, it may be a crank shaft sensor. Happened to me, intermittently stalled out.I just had to wait a couple minutes and it would start up again.
gmp211 is offline
post #9 of 21 Old 06-01-2009, 02:13 PM
WhiteOut
WhiteOut's Avatar
He already replaced it, its in the OP :
Have you had a tuneup done recently, what is the condition of the plugs/wires. Running Seafoam through the engine will help break up engine deposits which could help.
WhiteOut is offline
post #10 of 21 Old 06-01-2009, 02:15 PM Thread Starter
gregsbabe1
It had an extensive maintenance done on it 4 months ago. When we go for a code it says "Done"
post #11 of 21 Old 06-01-2009, 02:55 PM
00RedWJ
2006 WK
Done meens no codes. That's not going to help you. When it's in no-start mode, see if you can hear the fuel pump cycle on in the rear when you turn on the ignition. It sounds to me like it's fuel starved, which is probably your fuel pump. Like I said earlier, it is a known common problem on these trucks
2000 Red Laredo WJ
00RedWJ is offline
post #12 of 21 Old 06-01-2009, 02:58 PM Thread Starter
gregsbabe1
I hear something and some sort of rattle noise behind the glove box. how do I check for fuel pump issues? My husband and I are not familiar with jeeps.
post #13 of 21 Old 06-01-2009, 04:23 PM
WhiteOut
WhiteOut's Avatar
Have your husband kneel by the rear wheel well on the drivers side while you turn the key to the "ON" position. he should hear a whine, this is the fuel pump. If you dont hear a whine your pump isnt priming. You could also check the fule pressure at the rail.
WhiteOut is offline
post #14 of 21 Old 07-29-2009, 06:03 PM
jeepsgonewild
I have spent $1000 trying to figure my stalling issue so I know it is very difficult to pinpoint a remedy. It drove me nuts!! Well, I just put in a new PCM yesterday and I havn't had one issue since, for a 96 gc laredo model the PCM ran me $300 (without core) at autozone.
It's a remanufactured PCM, 100% computer tested to be working properly so it should be just as good as a new one. If you bring your old PCM to autozone you get a discount of $85 in my case at least. The one from autozone is reprogrammed, don't know if it is plug and play but just had Jeep dealer "program" it for me since they said it has to be programmed. Before all of this I thought I fixed it a few times.
I had changed fuel filter which had black gas coming out from the dirt build up, thought this was it, but it was not. I changed a vacuum hose that was not even connected, thought that was it, wasn't. Also had changed, temp coolant sensor, crank sensor, iac, tps, air filter, ignition coil, pickup coil, spark plugs and wires. thermostat and housing, finally I just bought the PCM and it has been working nice for 2 days, has not been "glitching" out on me where I get a sudden rpm drop. Goodluck!!
jeepsgonewild is offline
post #15 of 21 Old 07-29-2009, 07:35 PM
Double E
Double E's Avatar
Ok...Here ya go. Post #6 mentioned it but if you don't wanna search, here's your 1 bone for being a newbie.
I knew I had read about this from months & months ago....did a search & hope this will help.
Given the amount of $ you've spent, you might try to see if there's someone with some options for you. (Friend with a jeep & some technical skills that can look this over and assist.) Maybe some pizza or proper dinner would go a long way to rely on a friend. Anyway, if the part gets pulled and there's no issues with it upon very close examination, you'll know there's something else to look at. In any case, look this thread over.
http://www.jeepforum.com/forum/showthread.php?t=666072
It also refers to this thread which will assist whoever goes after this issue.
http://www.jeepforum.com/forum/f13/wj-pcm-repair-overhaul-666225/
Good luck with this...
Double E is offline
2000 Grand Cherokee Stalling problem garyo WJ Grand Cherokee Forum 6 04-17-2016 02:40 PM
1995 Jeep Grand Cherokee Limited 4x4 Stalling/Rough Idle HELP!!! Keith1975 ZJ Grand Cherokee Forum 22 08-05-2012 07:41 PM
2000 jeep grand cherokee times9 ZJ Grand Cherokee Forum 2 01-07-2010 06:44 PM
96 Jeep Grand Cherokee Laredo 4.0 Inline 6 Stalling 181K No codes jeepsgonewild ZJ Grand Cherokee Forum 37 08-08-2009 07:50 PM
05 Jeep Grand Cherokee Stalling Issues Moen0028 WK Grand Cherokee & XK Commander Forum 2 10-15-2008 03:32 PM
