2000 Jeep Grand Cherokee Limited Quad AWD front end noise whine howl. - JeepForum.com
 1Likes
post #1 of 26 Old 03-16-2011, 08:24 PM Thread Starter
whalen62
Wj 2000 Jeep Grand Cherokee Limited Quad AWD front end noise whine howl.
Jeep is full time 4WD AWD - I get a howling / whining noise from what appears to be the front end of my Cherokee - I only get the noise when I am accelerating and maybe a second or two after I take my foot off the gas pedal. If I am coasting in drive or neutral no noise. As soon as I hit the gas - the noise comes back instantly. The noise gets louder with increased speed - turns to more of a howling. I took it to one place and they said it was the front drive shaft - they took it out and said the noise went away.
Took it to a gear guy and he said not in the drive shaft - he thinks its a rear end noise? Another guy said it could be the transfer case? Anyway to diagnose the problem from the symptoms?
Also at times if I am backing up and have the wheels cut really hard I will get a clunking noise that seems to be coming from the front end as well. Any help would be appreciated. The Jeep is AWD
whalen62 is offline
post #2 of 26 Old 03-16-2011, 09:43 PM
wj0313
2003 WJ
Sounds to me like your front differential is on its way out. Howling on accel while the fear is driving and clunking from too much lash.
wj0313 is offline
post #3 of 26 Old 03-16-2011, 09:49 PM
RudeRaptor
That was my case when I had similar howling. Rear diff went kaput...
My Grand Cherokee is faster than 80% of all snakes. To give you a reference point, my Jeep is somewhere between a snake and a mongoose. And a panther.
RudeRaptor is offline
post #4 of 26 Old 03-16-2011, 09:52 PM
Kheeney5
From what I have found, it is common for GC's to
1.) Kind of skip when you have the wheel cut all the way, this is because of the 4wd all time engaging
2.) Whining noise upon acceleration (not sure how bad?)
3.) Make weird noises when you compress the brake and then switch gears.
Kheeney5 is offline
post #5 of 26 Old 03-16-2011, 10:01 PM
narnwv
narnwv's Avatar
so did YOU drive it after the front drive shaft was out to confirm or deny if it was the drive shaft?
~Aaron
narnwv is offline
post #6 of 26 Old 03-17-2011, 07:28 AM
mmandel
which noises do you refer to? coming from the brake pedal or from the drivetrain?
mmandel is offline
post #7 of 26 Old 03-17-2011, 10:38 AM
Janibeans
Same exact thing is happening with mine. If you find out what it is before I go to get it fixed within a month, let me know!
Janibeans is offline
post #8 of 26 Old 03-19-2011, 08:21 AM
Janibeans
just crawled under mine to find the TC side CV is toast. check where the boot goes into the CV, mine's ripped.
post #9 of 26 Old 03-19-2011, 10:05 AM
mnesta
What's the tc and cv?
mnesta is offline
post #10 of 26 Old 03-20-2011, 06:55 AM
Janibeans
Transfer case; the CV joint is the joint at the end of the shaft that allows it to attach to the transfer case and flex. Here's a picture of what I'm talking about:
I'm buying this part:
http://www.driveshaftparts.com/index...&productId=430
post #11 of 26 Old 03-20-2011, 07:43 AM
nickblack
Howling noises on acceleration sounds like a front diff. problem. Not uncommon for the front pinion bearings to loose their preload because of a faulty pinion nut/washer combo on the WJ, especially on the full time 4 wheel drive models. There is a TSB out for this where the nut/washer combo is replaced by a flanged nut which holds better. After 11 years this could be your issue and is a simple fix with the right tools. Before ripping up the front diff, go the dealer and ask them to reset the front pinion bearing preload with the flanged nut from the TSB. They will also change to a new style crush sleave, and probably have to change your pinion seal.. They will know what your talking about. The overwhelming majority of private shops have no clue what they are doing and are only good for brakes, mufflers, oil changes and the like. Many folks that call themselves mechanics are nothing more than oil changing monkeys.
cabrio85 likes this.
nickblack is offline
post #12 of 26 Old 04-08-2012, 08:21 PM
jaws626
Did you ever figure out what the howling/whine was?
jaws626 is offline
post #13 of 26 Old 04-08-2012, 09:32 PM
Merc1973
Probably not since the thread is over 1 year old and the OP has only posted once on this site...
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #14 of 26 Old 04-09-2012, 08:19 AM
super98lsc
Hey Janibeans is this picture a Rezeppa (sp) joint or a CV?
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #15 of 26 Old 04-09-2012, 08:35 AM
narnwv
narnwv's Avatar
That's a Rezeppa style CV joint.
~Aaron
narnwv is offline
Where is the fuse located for the heater blower on a 2000 Grand Cherokee Limited? hick2087 WJ Grand Cherokee Forum 3 01-18-2011 04:07 PM
jeep grand cherokee engine whine royboy2012 WJ Grand Cherokee Forum 3 12-21-2010 12:19 PM
2000 Jeep Grand Cherokee limited Head light issue. dooboy2112 WJ Grand Cherokee Forum 5 08-07-2010 02:04 AM
2000 Grand Cherokee Limited wipers size ??? Webb WJ Grand Cherokee Forum 3 11-17-2003 10:11 AM
very important horse power of 2000 grand cherokee limited v8 kulltogi WJ Grand Cherokee Forum 1 12-25-2002 05:09 PM
