2000 grand cherokee WJ, coupe issues. - JeepForum.com
post #1 of 7 Old 02-10-2012, 08:49 PM Thread Starter
Cadoc08
Hi there. I'm new to the forum and this is my first Jeep. So far I'm loving it, depsite the fact I've had to make a few repairs. It's nice to be able to get out into the mountains without having to barrow my brothers truck.
Ok, first issue: There's a whine coming from my rear end. It's noticable even at low speeds, and increases just slightly with speed. Doesn't seem to be brought on by any kind of conditions, it just does it every time I go anywhere. I called and asked the dealership and they "informed" me that this was normal on the all time four wheel drive models. They didn't sound very confident so I thought I'd ask if anyone else has experienced this and what they did about it.
I did check the fluid level earlier today, it was a tad low, nothing major, but I brought it up a little anyway but it didn't seem to make a difference.
My second issue kinda involves the first in a weird way.
By the way the dealership said this was normal too.
I know I need an alignment, it pulls to the right, vibrates at freeway speeds, and has some uneven tire wear. But what I'm experiencing is a little strange to me. At idle in drive, if I just let off the brake and let it go with no throttle it will move forward, but it... Wobbles, I guess you would say. I think the best way to describe it is that it feels like one of my tires is slightly egg shaped. And the whole rig will rock back and forth a little, not violently, but it doesn't seem normal in any way to me.
Here's the kicker, when it does this wobble, the volume of the whining noise seems to fluctuate in perfect unison with the wobble.
So has anyone experienced these problems either together or seperately? Could it all be my alignment and tires? Is this all "normal" operation? Any advice would be awesome. Thanks.
Cadoc08 is offline
post #2 of 7 Old 02-10-2012, 09:41 PM
thestig_wj
My guess is the whine and wobble is from a bent axle shaft....maybe? and uneven tire wear is bad tie rod ends
thestig_wj is offline
post #3 of 7 Old 02-10-2012, 10:31 PM Thread Starter
Cadoc08
I suppose it could be. I sure hope it isn't, but I guess that'll be one thing to look into. I would think I would be seeing some leakage at one of my wheel ends with that though. Hmmm, I've been wrong before. If all else fails I'm gonna rebuild the rig as soon as I can so I guess we'll see. Thanks for the advice. Anyone else have any ideas?
Cadoc08 is offline
post #4 of 7 Old 02-11-2012, 07:54 AM
zeekracing
these wjs have issues with the rear end gear wearing bad. Even with low miles. My rear started whining at 80k. It has 193k on it now still going strong but I am easy on it. I just put tires on it that whined louder then the rear. Problem fixed, haha. The vibe could be cause the tires are wore funny. Do you feel the vibe in the steering wheel or just in the vehicle?
2006 Jeep Wrangler Rubicon 4.0 6 speed, 3" lift , 33" Nitto Mud Grapplers, Warn 5k winch, snorkel, one crazy driver
zeekracing is offline
post #5 of 7 Old 02-11-2012, 08:11 AM
Redrum_1
Your wobble back and forth sounds like one of your tires has a belt that has shifted. That alone would cause vibrations at highway speeds. Both of my differentials make the whining noise. They been doing that now since I bought the Jeep. 30K later they sound the same. Once a tire starts wearing uneven its almost impossible to make it wear straight again. And it too could be some of your vibration also.
Good Luck!
2013 Dodge Ram 1500 Express Quad Cab. 5.7L Hemi 6 speed automatic 3:55 gears LSD with 20 inch rubber
2000 Jeep Grand Cherokee Limited 4.0L
2003 Nissan 350Z Enthusiast Model 6 speed manual
2002 Audi A6 Avant Quattro 3.0L Auto
Redrum_1 is offline
post #6 of 7 Old 02-11-2012, 08:59 AM
hyperlightboard
I agree with redrum broken belt/ply separation. Pretty easy to see if the jeep is off the ground. You said it is shaking so bring it in for a rotate and balance and tell them to look for ply separation when they do it....
Dink and Flicka
hyperlightboard is offline
post #7 of 7 Old 02-11-2012, 12:58 PM Thread Starter
Cadoc08
Thanks guys. Sounds like an alignment and some new tires are in order. It has 220K miles on it and I'm assuming the whine has been there for awhile, and it sounds like it hasn't caused a severe problem on your vehicles so I'm not gonna worry about it too aweful much... Untill my diff explodes that is. It's more annoying than anything. Yes, the vibration is felt in the steering wheel and only slightly felt elsewhere, most of my passengers think I'm crazy if I ask them if they feel the vibration, but they always comment on the wobble. My brother said he likes it because it makes him feel like he's going down the logging roads even though he's in a parking lot... Kids these days.
Cadoc08 is offline
2000 Grand Cherokee w/bad AC rnourse WJ Grand Cherokee Forum 6 12-02-2014 06:05 AM
4wd issues 2000 Grand Cherokee ltd alliedtech12887 WJ Grand Cherokee Forum 4 12-15-2011 09:44 AM
Will a 96 grand cherokee motor work in a 2001 grand cherokee with out major issues? blacksslumina WJ Grand Cherokee Forum 4 09-01-2011 11:56 AM
Can you interchange a 2000 grand cherokee 4.7 with a newer year grand cherokee4.7? cchopp0178 WJ Grand Cherokee Forum 6 12-21-2010 10:40 PM
2000 Grand Cherokee front driveshaft issues ncmedic964 WJ Grand Cherokee Forum 4 03-20-2010 11:04 AM
