2000 Grand Cherokee Transmission Crossmember - JeepForum.com
post #1 of 9 Old 06-24-2013, 03:08 PM Thread Starter
Deps
Hi, repair shop said I needed to replace the transmission cross member on my 2000 Grand Cherokee. Said it is still structurally stable, but there is good deal of rust in middle.
1. do I need to replace?
2. where can I find one? Called every salvage yard and seems only luck so far has been the dealer.
Thanks,
-D
Deps is offline
post #2 of 9 Old 06-24-2013, 03:58 PM
duranged
-D
1. depends how bad it is. pics? they said it was "structurally stable" so you might be able to clean it up.
2. part number 52058 940AB
2001 WJ Limited; 4.7L; 4.5" RK LA; 305:65:17 ProComp Xtreme AT; 231 HD w/ SS SYE; KOR sliders; ARB front w/Warn and in-cab controls; Custom4x4Fab rear; Dual Battery via 12voltguy.
duranged is offline
post #3 of 9 Old 06-24-2013, 04:20 PM
doityourselfMM
doityourselfMM's Avatar
If its surface rust, and just flaking, I would try to clean it up. A wire brush on even just a drill may work. Or you can start with 60 grit sandpaper and lightly work your way down. There are plenty of preservatives and restoration products on the market to choose from. I've used Eastwood Rust Converter and then Rust Encapsulator with good results on my undercarriage, shock towers, etc.
http://www.eastwood.com/paints/rust-solutions.html
doityourselfMM is offline
post #4 of 9 Old 06-24-2013, 06:00 PM
dillonjm
2013 WK
If you end up needing one I could probably ship you the rust free one in my garage.
You'd have to cover shipping though.
Let me know.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 9 Old 06-24-2013, 06:34 PM
nickblack
look on ebay or LKQ parts. They are a nationwide salvage company. I cant believe you cant find one. They made millions of WJ's and there are plenty in the salvage yards.
nickblack is offline
post #6 of 9 Old 06-24-2013, 07:21 PM
4North
Iron rock sells a high clearance one for $300 if you have some dead presidents lying around
4North is offline
post #7 of 9 Old 08-28-2013, 07:37 PM
JEA
$200 now
http://www.ironrockoffroad.com/Merch...egory_Code=PFW
JEA is offline
post #8 of 9 Old 08-28-2013, 09:14 PM
corpulent
I've used "row52.com" to keep track of WJs as they hit the local pick n pulls. (Someone always gets to that tow hitch first, though).
If new is $2-300, and yours is still structurally stable, I'd be inclined to wait until a wreck shows up at the junkyard. Couldn't be more than $50.
corpulent is offline
post #9 of 9 Old 08-28-2013, 09:40 PM
JEA
f*cked up today and bent part of mine when jacking up to change the tires. still fine i probably don't need to replace mine but meh if i do i'll go with an upgrade
JEA is offline
