2000 Grand Cherokee Stalling problem - JeepForum.com
post #1 of 7 Old 03-25-2008, 07:07 AM Thread Starter
garyo
Hello. I have a 2000 Grand Cherokee w/175K miles that has developed a stalling problem and is not throwing an error code. At one point in time, the vehicle stalled, would not restart, I had it towed and by the time it got to the mech it started and he did not find anything wrong. It stalls once or twice a month and with the exception of that one time restarts.
Yesterday I noticed something. It stalled, upon restart the fuel gauge read full(and the tank was 1/2 full) it ran fine for 10 minutes then the engine hesitated, and the fuel gauge kicked back to giving an accurate reading?!
I am not sure what to do here because no error codes are being displayed and this is a very intermittent problem.
Thanks
Gary
garyo is offline
post #2 of 7 Old 03-26-2008, 03:04 PM
fredp4rrot
Get yourself a new PCM. I had the same problems as well as many other symptoms.
fredp4rrot is offline
post #3 of 7 Old 03-28-2008, 10:27 AM
Dezelsky1
Stalling
I had a similar problem with my 94 GCL. It would run great and then suddenly just cut out. Mine would always restart, sometimes even while i was coasting.
Replaced lots of sensors, tuned it up, had the injectors cleaned, new fuel filter. As it turned out, it has run great now for two weeks plus, since i had the 'Crank Position Sensor' replaced.
Dezelsky1 is offline
post #4 of 7 Old 03-28-2008, 11:25 AM
pigoo
Your symptoms were/are the same as mine.
Short & sweet...change your Crankshaft Position Sensor!
- Nick
pigoo is offline
post #5 of 7 Old 04-17-2016, 02:20 PM
JeepLover6996
2000 KL Cherokee
2000 jeep grand Cherokee stalling prob
I have a 2000 jeep grand cherokee laredo, it runs awesome and well taken care of. But recently it has been stalling with no warning, i changed the rad, fuel filter some of the fuel line, thermostat, ignition coil, throttle body control. It gives no warning and it usually starts right away. But other times it takes a few minutes to start. Then runs and other times it stalls like 2-6 times in a day!!! What to do please help ?
JeepLover6996 is offline
post #6 of 7 Old 04-17-2016, 02:33 PM
vlackattack
This is the ZJ forum, you have a WJ so you want the WJ forum, here: http://www.jeepforum.com/forum/f310/ They were the same section 8 years ago when this thread was started, they've since split from each other. Radiator and thermostat replacement were a waste, those wouldn't cause stalling.
vlackattack is online now
post #7 of 7 Old 04-17-2016, 02:40 PM
JeepLover6996
2000 KL Cherokee
sorry
2000 Jeep grand Cherokee stalling gregsbabe1 WJ Grand Cherokee Forum 20 08-17-2015 02:07 PM
99 Grand Cherokee Stalling Problem pigoo ZJ Grand Cherokee Forum 16 07-09-2015 11:16 AM
95 Grand Cherokee Stalling Problem hondajeep ZJ Grand Cherokee Forum 10 04-16-2012 12:13 PM
Need Help diagnosing a problem with a 2000 Grand Cherokee daveaf ZJ Grand Cherokee Forum 2 03-29-2009 03:09 PM
Problem with my 2000 Grand Cherokee hypperboy ZJ Grand Cherokee Forum 4 11-07-2005 10:03 AM
