2000 grand cherokee mpg issues i6 - Page 3 - JeepForum.com
post #31 of 42 Old 04-28-2012, 09:17 PM
4Doors
My running average as of late is 17.8 and that is combined city/highway on 4" lift and 32" tires (true story), but I've got my tires filled with helium so I float most of the time (this may be a fabrication). Give it a shot.
4Doors is offline
post #32 of 42 Old 04-29-2012, 06:10 AM
cuttysark
hahaha LOL
yeah if you want good mileage, dont buy a jeep.. my WJ 4.7 gets only about 10% better milage then my 97 ZJ 5.2 did. albeit i have to do a tune up probably but still.. only about 350 KM/tank
cuttysark is offline
post #33 of 42 Old 04-30-2012, 04:47 PM
rlordjr
I have been paying close attention. On the way to school for carpool I will see 14 mpg. This is from cold start to 11 miles in mix of hwy and traffic. I reset computer at school and have over 20 mpg showing when reverse trip is finished and I am at work. Seems like operating temp is important
rlordjr is offline
post #34 of 42 Old 04-30-2012, 07:22 PM
nlynd1978
2006 XK Commander
Just a little bit.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #35 of 42 Old 05-08-2012, 08:05 PM Thread Starter
wyattwj123
calculated my tank mileage and i got 200 miles with a fuel tank thats horrible.. had to fill it up within 6 days i changed the spark plugs already fuel filter cleaned the air filter sea foamed i think i would no if it was a 02 sensor i need to get better gas
wyattwj123 is offline
post #36 of 42 Old 05-08-2012, 08:28 PM
mycreativename
Why do you think you would know if the O2 sensor was bad? Are you some sort of sensor-whisperer?
That being said, you are at 100k+ miles without knowing if they've been changed, chances are they haven't been.
But I've gotta be honest with you, you do nothing but short trips, ~10mpg isn't really all out of the realm of normal for how your trips are. Before I was driving to college and to work, I was getting 11/12mpg consistently, heck even now with doing about half highway half stop and go, I only get 15mpg. It's a Jeep, you're not going to ever get "good" mileage.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #37 of 42 Old 11-08-2013, 07:52 PM
rchinsp
I have a 2012 Jeep Grand Cherokee Overland that I bought new and now has 20,000 miles on it. I took it to my dealer for a oil change and asked him to stop the low tire PSI computer from flashing ( 3 of the 4 was flashing). Later I was told that my tires had Nitrogen in them and I had to go to the only tire store in town that could do this ( he said that due to my tires having a "Gray valve Stem" that my tires had Nitrogen in them). I was never told about Nitrogen in my tires until now. Did my Jeep come with the Nitrogen in them or was I sent to this Tire store to have Nitrogen put into my tires unnecessary.
rchinsp is offline
post #38 of 42 Old 11-08-2013, 08:01 PM
brianestep
Wrong forum friend. Try the WK2 threads. This is WJ, 1999-2004. We put american-made oxygen in our tires!
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #39 of 42 Old 11-09-2013, 07:18 AM
Cirruslydakota
Typically a green valve stem indicates nitrogen filled. I haven't heard of gray indicating that. My Mazda has the gray caps as well but its matched to my tpms. Take a picture if you have a chance.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #40 of 42 Old 11-09-2013, 09:30 AM
Jeeples
Jeeples's Avatar
Gray valve stems are typically used on vehicles equipped with TPMS sensors. Green usually denotes nitrogen.
Nitrogen is, IMHO, just a way for tire shops to make more money for very little gain to the consumer. Either take it back and tell him to fully deflate your tires and fill 'em will regular air or find a shop that's more competent.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #41 of 42 Old 11-09-2013, 10:13 AM
Idano12
Why deflate and refill ? You can just top them off with regular compressed air.
Idano12 is offline
post #42 of 42 Old 11-09-2013, 01:24 PM
rchinsp
I double checked all of my Valve Stems again and all are Gray. But I discovered that two of the Stems had a White Center Cap (appears the other two Stems have lost their Center Cap) and with a Magnifying lens I was able to read in green letters across the White Cap that said "Nitro Fill". Thanks for helping.
rchinsp is offline
2000 grand cherokee WJ, coupe issues. Cadoc08 WJ Grand Cherokee Forum 6 02-11-2012 12:58 PM
4wd issues 2000 Grand Cherokee ltd alliedtech12887 WJ Grand Cherokee Forum 4 12-15-2011 09:44 AM
Will a 96 grand cherokee motor work in a 2001 grand cherokee with out major issues? blacksslumina WJ Grand Cherokee Forum 4 09-01-2011 11:56 AM
Can you interchange a 2000 grand cherokee 4.7 with a newer year grand cherokee4.7? cchopp0178 WJ Grand Cherokee Forum 6 12-21-2010 10:40 PM
2000 Grand Cherokee front driveshaft issues ncmedic964 WJ Grand Cherokee Forum 4 03-20-2010 11:04 AM
