-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   2000 grand cherokee mpg issues i6 (http://www.jeepforum.com/forum/f310/2000-grand-cherokee-mpg-issues-i6-1361777/)
wyattwj123 04-26-2012 08:26 PM
hey ive had my jeep for about 4 months got the I6 and it runs great and all but my mpg is horrible like 10 mpg and i have to fill it up alot and i dont have any leaks and my computer says 200 miles to empty everytime i fill it up and i replaced my fuel filter today and sea foamed it and now it says 260 miles to empty im very shocked haha i dont really trust the computer but how can i fix my gas mileage theres something wrong thank you
Sohcvtec1995 04-26-2012 08:49 PM
leave it in the driveway, buy a prius.
When was the last tune up? tire pressure? anything dragging. what else have tried/done?
mycreativename 04-26-2012 08:50 PM
For future reference, you might wanna try out this revolutionary tactic of punctuating your sentences.
Now to get to the issue. Is this a new issue, as in you've been getting better mileage and all of the sudden it plummeted, or have you always been getting extremely low mileage?
Ignore the computer completely, its useless. Get your MPG calculations by hand, as its the only reliable way to find out what you're actually getting. Is the 10mpg by hand or by EVIC (the computer)?
How many miles are you sitting on? Have you kept up with maintenance (mainly the O2 sensors is what I'm getting at here)? Do you drive like a pissed off teenager? That will have the most effect is just how you drive it.
Since you just replaced the filter today, I would fill the tank tonight and then again in a couple days from now to actually find out what mileage you're getting. Do it by hand. In case you don't know how to do so:
1: Fill tank completely
2: Reset trip odometer
3. Go about your business for a couple days
4. Refill tank completely again
5. Divide number of miles driven (from your trip odometer) by number of gallons put in, boom there you go.
6. Rinse, lather, repeat.
WJlover 04-26-2012 08:58 PM
replace air filter or upgrade air intake.
keep tires at proper pressure.
COAST to a stop, dont stop short. if you see a red light coming, just let off the gas and coast as long as you can before you need to brake, but GRADUALLY brake. i see all these fools braking super hard at redlights all the time.
when taking off from a red light, dont SPEED, but get to the highest gear possible, as fast as possible...without being a danger to the other drivers.
on that note, always try to drive in your highest gear.
do a real fuel system cleaning. sea foam is great for what you pay, but a real system cleaning is what you need.
just...dont do it at jiffy lube. i dont trust anything they do.
use the oil the manufacturer recommends.
use cruise control at all given oppurtunities.
decrease vehicle weight where possible.
change spark plugs (i hear e3 works good, but i also hear their gimmicky)
fuel pump
buy lighter wheels
use nitorgen in your tires instead of air
thats all i got right now, i know im missing something
wyattwj123 04-26-2012 08:59 PM
i bought it not too long ago, and it has always got bad mpg and my tank is full of right now and im in the process of calculating it. nothings dragging i havnt checked my tires yet but. im thinking about installing new spark plugs how much would they run me and could i install them myself
WJlover 04-26-2012 09:04 PM
not sure how much e3 costs but alot of people swear by the cheap ones at autozone/walmart
think their like 4 bucks a piece? or am i time traveling right now.
and on the i6 their pretty easy to do yourself, just becareful. they can get stuck sometimes and your going to probably get angry with it, and pull at it with channel locks and tear the boot and or wire....
patience is key, which is what i dont have.
anyways, spark plugs can be either really cheap or really expensive, just depends on if you want gimmick or economic.
wyattwj123 04-26-2012 09:10 PM
oh ok thats not expensive what about 02 sensors
the88thpianoman 04-26-2012 09:13 PM
NEVER use the E3 plugs in the WJ! You WILL get all sorts of misfires and possibly burn out the ignition coil. OEM champion copper core (or NGK for the few that had those OEM) is the way to go. Gimmicks will never pay off, especially on spark plugs.
Same goes for the nitrogen tire fills. The nitrogen won't cause any damage like the E3 plugs will, but you may as well just throw 40 bucks in the garbage disposal.
WJlover 04-26-2012 09:14 PM
it was ages ago last time i bought one, but i want to say it was around 100 bucks? not 100% sure
as for installation, never had to do one myself. but shouldnt be hard.
WJlover 04-26-2012 09:16 PM
the nitro was free for me, and i believe free for the life of my tires as well.
but yes its expensive for a very small effect.
if your getting it free, then why not
nlynd1978 04-26-2012 09:21 PM
first and foremost, assuming your referring to the jeep in your profile, lets start with the obvious,
1. how many miles on the motor?
2. what size are your tires? stock size or over-sized?
3. check engine light? and history codes?
4. What did the previous owner say about the maintenance? did you ask for records?
mycreativename 04-26-2012 09:27 PM
E3 spark plugs are a complete and total gimmick and waste, you'll create all sorts of problems with them. Go look through your local auto parts store's flyers, one of them is always running a special on spark plugs. You're looking for Champion Coppers. DO NOT let them upsell you on them, you want the plain jane copper plugs.
Don't waste your money on Nitrogen in your tires or on any sort of upgrades right now. In factory stock form, which means normal air in tires on OEM wheels, normal air box, etc, you should be getting at least 15mpg if not more.
Also, it just occurred to me to ask. What are your trips like? Aka how far from school/work/etc are you. Are your trips very short and non highway based? My girlfriend's 4 banger VW Beetle was rockin along at 10mpg for the summer because she was driving less than a mile at a time; the engine never had time to warm up and she never really took it above 30, it was all stop and go traffic. That could definitely affect your mileage in a big way. I notice when I don't drive to school (~25 miles round trip all highway) my mileage will be significantly lower the next time I fill up.
wyattwj123 04-26-2012 09:29 PM
108000 miles stock tires no lights or codes and no previous records
wyattwj123 04-26-2012 09:36 PM
my work is like a mile away and i go there every day and also to friends house that are a few miles away and have to fill up every week
the88thpianoman 04-26-2012 09:46 PM
If it's free, then yeah, go for it. Otherwise you're spending an awful lot of money to "upgrade" from the 78% concentration of nitrogen already in the atmosphere to a roughly 98% concentration after combining pure nitrogen with the volume of atmospheric air already in the tire at a pressure of one atmosphere.
There's really no discernible difference between a mixture of 78% nitrogen, 21% oxygen, and 1% argon/other crap and 98% nitrogen, 1.9% oxygen, and .1% argon/other crap, as far as tire life and performance are concerned. The benefits of regularly checking and maintaining the proper tire pressure with normal air will far exceed those of using a nitrogen fill.
The time now is 11:05 PM.
