2000 Grand Cherokee front driveshaft issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2000 Grand Cherokee front driveshaft issues
Jeepforum Coupon for Iron Rock Off RoadRuffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 03-20-2010, 09:24 AM   #1
ncmedic964
I have a 2000 Grand Cherokee Laredo 4.7L v8 Quadra-Trac all time 4wd with a bad front drive shaft. The style shaft that is in mine has the CV style joints both front and rear. I purchased a new shaft from eBay but was not aware that those come in different lengths the shaft that I purchased is approx. 1.5 inches longer than my old shaft. I need to know if anyone has one of these available as I have looked EVERYWHERE and cannot find the right shaft. Also, I have heard that those can be converted to a U-joint style but I am not aware of what I would need to buy to do this conversion or where to find the parts. If anyone could help me out that would be fantastic thank you so much.
P.S. I have found these on eBay in the range of 300.00 but I am desperately trying to keep from needing to spend that amount. Thanks again.
ncmedic964 is offline   Reply With Quote
Unread 03-20-2010, 10:29 AM   #2
QuadraTokn
1930 WJ
Thats really weird the length is different because the lengths should all be the same for the front drive shaft 1999-2004 no matter which t-case you have.
To convert to the u-joint style (highly recommended around here, required if you offroad) you also need the yokes, but there is a special torquing sequence for the yoke that goes into the axle, so you would need a shop to do thjat part. Also replace the pinion seal while you're at it.
QuadraTokn is offline   Reply With Quote
Unread 03-20-2010, 10:34 AM   #3
redhatman
redhatman's Avatar
The front driveshaft lengths are different depending on the T-Case.
IRON ROCK OFF ROAD: Front Driveshaft Conversion Kit
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote
Unread 03-20-2010, 10:38 AM   #4
QuadraTokn
1930 WJ
ahh well carolina told me that it wouldnt matter. I told them I had a 247 at the time, and that I was switching to a 242.
I remember measuring some t-cases I had and IIRC they had the same measurements.
Unread 03-20-2010, 11:04 AM   #5
redhatman
redhatman's Avatar
Hmmmm, weird. At IRO they are different lengths for different T-Cases. Same yokes though.
-Pat
