2000 grand cherokee - JeepForum.com
post #1 of 3 Old 01-12-2014, 08:11 PM Thread Starter
2000gch
2000 grand cherokee
Hello fellow members
I have an issue my 2000 grand cherokee has problems.
here is the story, i pulled out of the parking lot of the post office and all of a sudden it ran very bad started misfiring really bad and on the way home it stalled about 10 times in a 2 mile distance. it sat for 2 months because i could not figure out what was wrong. it ran fine until the jep warmed up then the misfiring and stalling comes. i drove it to the dodge dealer and got a diagnostic they scanned the truck and it came back that the coil was bad cam and crank sensor was bad i changed the parts and installed new spark plugs now the truck wont start it turns over spits gas out of the throttle body. engine was put to tdc and cam was aligned check engine is on it says its the ckp circuit need help please.
2000gch is offline
post #2 of 3 Old 01-12-2014, 09:02 PM
Krooser
What engine?
Krooser is offline
post #3 of 3 Old 01-13-2014, 07:33 AM
StrokedWJ
StrokedWJ's Avatar
Are you sure the engine was at TDC of the compression stroke? If you set it on the exhaust stroke you'd be 180* out and would explain backfiring out of the throttle body.
Did you buy new sensors? If so what brand?
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
