2 A/C vents throughput crappy - Page 2 - JeepForum.com
post #16 of 28 Old 04-20-2012, 02:05 AM
MWF
Mines the same, although reversed for rhd. Was a bit of a wtf moment when I realised the centre vent was one tube too.
MWF is offline
post #17 of 28 Old 05-03-2012, 03:19 PM
jclaudii
This needs to be fixed on mine, I've even at a point where the kids are sweating in the back asking when it's going to get colder. I'm thinking of rigging up some computer fans on the vents to give them some turbo power or an ice chest in the back with some fans pointed at them! A rear facing car seat gets no airflow at all and our little one is a ball of sweat! My dream would be to add a rear evaporater and some T-lines and tie into the front system so I can have rear air and font air.
jclaudii is offline
post #18 of 28 Old 06-05-2012, 07:58 PM
ibreb3
Keeping this thread alive as I have the same problem and I'm hoping someone solved theirs and can tell us how they did it...please...bueller...bueller...lol
ibreb3 is offline
post #19 of 28 Old 06-22-2012, 02:50 PM
beezerbiker
No kidding, please someone figure this out. I have sealed up the center vents with foam - it's better, but still practically no air our of passenger side center vent. It makes no sense since they are on the same airshaft - weird. Vent to the right of that on dash is basically useless. Overall the whole system is weak but the motor sounds like it's blowing fine. I did the blend door repair also and it had no effect. I really hope someone can help!!!
beezerbiker is offline
post #20 of 28 Old 06-22-2012, 02:58 PM
narnwv
narnwv's Avatar
I have the same problem, and when I pulled out my radio, the duct for the vent that's just to the left of the passenger air bag was cut up, almost like somebody replaced the motor that's there, without taking the dash apart. A little duct tape helped, but it's still weak.
TIP: Point all vents towards the ceiling, and use recycle. The air will flow up along the ceiling, and be pulled back along the floor (where the recycle input is) This cools the vehicle off quickest, and gets air into the back seat better.
~Aaron
narnwv is offline
post #21 of 28 Old 06-23-2012, 06:57 PM
HVACNY
2013 WK
When you pulled the radio you were able to see the duct connections?
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #22 of 28 Old 06-23-2012, 09:52 PM
kc2mrg
Originally Posted by Cirruslydakota View Post
the only way to correct that is to rip the dash apart. Not a fun job for sure.
i dont want to hear it isnt fun, i just pulled the dash of a 2011 BMW 550xi, now that was not fun! it had the a/c evap core leaking, and the amount of wiring behind there and under the center console, OMG! and then pulling half the engine apart to disconnect the a/c lines? i mean, come on BMW and it pays like 10 hours warranty to do the job
i really doubt the WJ looks like this after removing the dash...
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #23 of 28 Old 07-11-2012, 05:18 PM
Dylan484
Starting it back up, I'm having the same problem.
Dylan484 is offline
post #24 of 28 Old 07-11-2012, 06:30 PM
beezerbiker
I do think there is a seal or something in the dash that simply collapses. The problem is deep in the dash I'm convinced.
post #25 of 28 Old 07-11-2012, 07:02 PM
narnwv
narnwv's Avatar
If I get time, I'll get some pictures of the gap.
Sent from my Atari 2600 using JeepForum App
~Aaron
narnwv is offline
post #26 of 28 Old 08-08-2012, 12:27 PM
Kheeney5
Bump. Any updates on this? I am too having this problem. I hear the cabin airfilter can be clogged. But that is an optional accessory I believe. I'll have to see if I have it.
Kyle -1999 WJ Limited
Misfortuned WJ Build Thread: http://www.jeepforum.com/forum/f22/misfortuned-wj-build-thread-1191233/
Kheeney5 is offline
post #27 of 28 Old 07-22-2014, 03:00 PM
rmorrow1970
just a bump here....ok gurus......consensus? this is obviously a common problem.....im certain those more skillful have solved it...please let us know how! it is too hot in florida to live this way!! thank you
Rick
rmorrow1970 is offline
post #28 of 28 Old 07-22-2014, 05:05 PM
Thomahawk
Maybe this is your problem,
Replaced foam while i did blend and recirc door, more pics in my build thread.
Buildthread
Thomahawk is offline
Air vents grant1ja WJ Grand Cherokee Forum 6 01-27-2012 12:56 PM
Crappy Suspension on old WJ, How to revive...? bkloos WJ Grand Cherokee Forum 8 12-19-2011 10:55 AM
crappy mileage adhdlacrosse16 WJ Grand Cherokee Forum 5 11-08-2011 02:30 PM
center vents blow about 10 degrees warmer than pass vents. likely not blend doors jclaudii WJ Grand Cherokee Forum 0 06-24-2011 10:46 AM
crappy fuel mileage MGDWJ WJ Grand Cherokee Forum 1 04-09-2010 11:19 PM
