2 A/C vents throughput crappy - JeepForum.com
post #1 of 28 Old 02-17-2012, 03:55 PM Thread Starter
OTownDaddy
2007 XK Commander
Wj 2 A/C vents throughput crappy
So, the weather has been fantastic recently, so I haven't been using the A/C. Yesterday, I decided to turn it on (it hit 82) and noticed that 2 of the vents weren't blowing at full power. Attached pic has them outlined in red. The other 3 have acceptable flow, although they too don't feel like the one in green (it has by far the most power.
Any ideas as to what might be the issue and a possible fix?
2007 XK Limited 4x4 | QD-II | 18" wheels (gotta dump these for some 17s) | The rest is stock
OTownDaddy is offline
post #2 of 28 Old 02-17-2012, 07:25 PM
Cobra Jeep
I have noticed my 99 does that. Exactly the same as you have pictured. The red ones do not flow very much, and the green one does, so does the one on the left of the steering wheel. Havent thought to check the one on the far right.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #3 of 28 Old 02-17-2012, 07:37 PM
Gran_Paradiso
2015 Summit
Gran_Paradiso's Avatar
2017 WK
I do know the two middle ones come from one outlet. I had to add some foam to seal the channel connecting to the hvac unit. It leaked air before it came out of the vents.
Gran_Paradiso is offline
post #4 of 28 Old 02-17-2012, 07:59 PM
gtg413i
2003 WJ
i notice the same thing on mine. I'd just chalk it up to another WJ thing / design flaw / quirk / uniqueness / annoyance / $$ to fix. Maybe it has to do with the heater treater I did. Did you do that to yours.
Sorry for the pessemistic attitude, just got back from trying to figure out why the WJ ran out of coolant and not too happy with why they require some special HOAT coolant. I think I solved the coolant leak due to upper radiator hose clamp being loose.
Brian's Black Betty Build:
gtg413i is offline
post #5 of 28 Old 02-17-2012, 09:02 PM
99WJdan
Same here on my 99'. Also the ones on the floor blow poorly as well.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #6 of 28 Old 02-17-2012, 09:34 PM Thread Starter
OTownDaddy
2007 XK Commander
Well, at least it's not a unique issue
Do you have to remove the dash to check out what's up or can you just remove the plate around the stereo?
post #7 of 28 Old 02-17-2012, 09:40 PM
Gran_Paradiso
2015 Summit
2017 WK
I took the bezel trim or plate as you say and the stereo out. I bought some of that narrow foam weather strip at the hardware store and resealed the connection to the HVAC duct. My foam deteriorated and air diverted away from exiting the vents.
post #8 of 28 Old 04-19-2012, 04:15 PM Thread Starter
OTownDaddy
2007 XK Commander
Reviving this as I'm thinking before it gets out of hand hot here in Orlando, I'll be needing to get this sorted. I think it needs a recharge, as it just doesn't blow as cold as expected. That's the easy part.
The 2 center vents come from the same place, seems odd that one blows like a madman and the other barely blows. Did a cursory check of the A/C path leading into the vent and all seems OK. Still wondering why one flow awesome and the other, well, blows (in a bad way).
Also, noticed the other day when I had the A/C on that when I sometimes accelerate hard, my A/C switches to come out of the defrost vents, then switches back to normal A/C vent flow. Is this a vacuum line (like the one under the battery tray) issue?
post #9 of 28 Old 04-19-2012, 05:01 PM
HVACNY
2013 WK
Before i fixed my blend doors i had the exact problem.Wasnt blowing cold on one side and vents were strong in the middle,weak on the sides.After the blend door fix my vents are balanced and blow hard out all of them.I dont understand how the blend doors affect velocity,but it did on mine.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #10 of 28 Old 04-19-2012, 05:11 PM Thread Starter
OTownDaddy
2007 XK Commander
I don't have dual climate...but I guess I still have a blend door of sorts, right? Diverts air to defrost, floor, etc? Wonder if that's the issue...
post #11 of 28 Old 04-19-2012, 05:24 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
There's a mode door as well as a blend door in the MTC system. The blend door is responsible for the mix of hot and cold air and is electronic. The mode door changes the pathway through HVAC box determining which vents are blowing. This one is vacuum controlled. The blend door on MTC models doesn't have the same issue as the AZC models since it doesn't do the same calibration routine that breaks the blend door axles.
I'd say its probably an air leak in the system somewhere.
~Richard
billzcat1 is offline
post #12 of 28 Old 04-19-2012, 05:25 PM
billzcat1
2003 WJ
Check out this TSB: http://wjjeeps.com/tsb/tsb_wj_240799.pdf
~Richard
post #13 of 28 Old 04-19-2012, 08:06 PM Thread Starter
OTownDaddy
2007 XK Commander
Very interesting. Wonder if there is something at work that would make one center vent blow less than the other. Maybe they each have tubes that supply each of them? Time to check that FSM.
Now to track down vacuum lines...
post #14 of 28 Old 04-20-2012, 01:08 AM
MoparMan1990
1992 XJ Cherokee
I've had the same issue I never really bothered to mess with it because it blows fine on the drivers side
MoparMan1990 is offline
post #15 of 28 Old 04-20-2012, 01:12 AM
Cirruslydakota
Same here, the center vent closest to the drivers side always blows more than the one on the passenger side. But since im always the driver who cares? lol But really, its a design flay, a very strange one at that. Id suspect a seal leak of some sort and the only way to correct that is to rip the dash apart. Not a fun job for sure. FWIW, I got my two front windows tinted to match the rear and so far this has helped a ton!
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
Air vents grant1ja WJ Grand Cherokee Forum 6 01-27-2012 12:56 PM
Crappy Suspension on old WJ, How to revive...? bkloos WJ Grand Cherokee Forum 8 12-19-2011 10:55 AM
crappy mileage adhdlacrosse16 WJ Grand Cherokee Forum 5 11-08-2011 02:30 PM
center vents blow about 10 degrees warmer than pass vents. likely not blend doors jclaudii WJ Grand Cherokee Forum 0 06-24-2011 10:46 AM
crappy fuel mileage MGDWJ WJ Grand Cherokee Forum 1 04-09-2010 11:19 PM
