2.5" - 3.5" Lifted WJ Grand Cherokees - Picture Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2.5" - 3.5" Lifted WJ Grand Cherokees - Picture Thread
Awesome savings at openboxoffroad.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNitro Gear Packages Now Available at Rockridge 4wd
Closed Thread
Unread 01-13-2015, 01:26 PM   #1
ChrisHager
ChrisHager's Avatar
The following pictures depict 2.5" - 3.5" lifted WJs. Please note, lift heights are not guaranteed. Many factors determine the final height of any suspension setup. Each post contains pictures with details to help minimize lift height discrepancies.
If you would like your pictures included in this thread, please post your information HERE. If the criteria is met, you post will be considered.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Quick reply to this message
Unread 01-13-2015, 02:17 PM   #2
ChrisHager
ChrisHager's Avatar
tsconver
Lift: IRO Long Arms Front and Adjustable Rear Lowers, 3in IRO Springs and 0.75" KOR Spacers, JKS Quick Disco Front, Addco Rear Sway Bar, MX-6 Shocks
Wheels: 15x8 Cragar Soft 8
Tires: Treadwright 31x10.5 MT
Additional Information: Homemade Front Bumpstop Extensions, Front and Rear ARB Air Lockers, 4.10 Gears
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-13-2015, 02:23 PM   #3
ChrisHager
ChrisHager's Avatar
GraKee99
Lift: 2.5" Rusty Springs, Skyjacker Front Shocks, Rough Country Rear Shocks, JKS Track Bar, JKS Quick Disconnects, OME Steering Stabilizer
Wheels: 15x7 Cragar Soft 8
Tires: 31x10.5 MTR TreadWright
Additional Information: Trimmed lower corner of front bumper, 2.5" Front Bumpstop
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-13-2015, 02:46 PM   #4
ChrisHager
ChrisHager's Avatar
lloyd877
Lift: Rustys Offroad 2.5"
Wheels: Wrangler Wheels
Tires: 265/70R16 Treadwright Guard Dogs
Additional Information: K&N Oiled Drop-In Filter, MagnaFlow Muffler 2.5" Tailpipe, Pilot Fog Lights, Hella 500FF, Cobra CB 3' Fire Stik, 10" Kicker CVR Rockford Fosgate Punch 300.1 and 400.4 Infinity Reference Speakers All Around
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-13-2015, 02:50 PM   #5
ChrisHager
ChrisHager's Avatar
WJRON351
Lift: 3" IRO Lift with Pro-Comp MX-6 Shocks, IRO Coil Retainers Front and Rear
Wheels: 16x7 Cragar Soft 8
Tires: BFG KM2 32" (235/85/16)
Additional Information: 3" home-made front bumpstop extension, Warn Offroad lights, Home made SS front guard powder coated black, Sonar black taillights, Rugged Ridge taillight guards, K&N FIPK2, Black aftermarket Headlights, JK Wrangler fuel door
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:15 AM   #6
ChrisHager
ChrisHager's Avatar
-Shoey-
Lift: Rustys 2.5" BB
Wheels: Moabs
Tires: 255/75/17 BFG KM's
Additional Information: Don't do this - Backing up and turning, no bueno.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:16 AM   #7
ChrisHager
ChrisHager's Avatar
-Shoey-
Wheels: OEM
Tires: 265/70/17 BFG AT
Additional Information: Rubbed just a smidge here and there.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:21 AM   #8
ChrisHager
ChrisHager's Avatar
02jeepgrand
Lift: 2.5 Kevin's Off-Road Budget Boost with Upcountry Springs
Wheels: JK Wheels
Tires: 265/70R16 General Grabber AT2
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:40 AM   #9
ChrisHager
ChrisHager's Avatar
lakailimited06
Lift: IRO 3" Coils
Wheels:
Tires: 33x10.50 KM2
Additional Information: D30 4.10s Aussie/8.8 4.10s Aussie/242 SYE, Trimmed Fenders, Custom Skids/Bumpers
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:45 AM   #10
ChrisHager
ChrisHager's Avatar
winterun
Lift: 2.5" KOR BB
Wheels: Pro Comp Alloys 16x8
Tires: 245/75/16 Goodyear MTR's
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 09:51 AM   #11
ChrisHager
ChrisHager's Avatar
platinum5.9
Lift: OME HD Coils, Extreme Engineering 1" Spacer, MX6 Shocks, OME SS/Kevin's Fit Kit
Wheels: 17" JK Moabs
Tires: 255/75/17 BF Goodrich Muds
Additional Information: Muffler Delete/Magnaflow Cat, Stock Skids, Duplicolor Bedlined Rockers
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 10:07 AM   #12
ChrisHager
ChrisHager's Avatar
huntandfish
Lift: Iron Rock Offroad 3" Coils, IRO Rear Sway Bar End Links, Doetsch Tech 8000 shocks, Addco Rear Sway Bar.
Wheels: OEM with RC 1.5" Wheel Spacers
Tires: Cooper Discoverer STT 245-75R16
Additional Information: No trimming and no rubbing while sway bar connected. Only rubbing on front bumper while fully flexed.
Note: The following are various photos from different times with slightly different looks due to side steps, wheel spacers, addco, and sliders which were removed and installed at various dates. Other small changes include JKS Bar pin Eliminators, Red Shock Boots from IRO, and Tenneco HD Steering Stabilizer.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 10:25 AM   #13
ChrisHager
ChrisHager's Avatar
jamtoy
Lift: 2.5" KOR Spacers, Front Up-Country Springs, Rusty's Shocks
Wheels: Steel JK Wheels
Tires: 31" TreadWrights
Additional Information: Carolina Double Cardan Front Driveshaft, Westin Brush Guard, Hella's and Harbor Freight HID's (not shown), Midland 75 3ft Firestick, Steel Mesh Grill, Cut Front Bumper in Half
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 10:44 AM   #14
ChrisHager
ChrisHager's Avatar
Hend0
Lift: 3.5" Rancho RS5000 Suspension
Wheels: Ultra Rogue Black Fnish
Tires: 265/75R16 Cooper Discoverer STT
Additional Information: Trimmed the fenders a little.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 01-14-2015, 11:04 AM   #15
ChrisHager
ChrisHager's Avatar
WJRON351
Lift: 3" IRO Coils, Pro-Comp MX-6 Shocks, IRO Adjustable Front Lower Control Arms, 3" IRO Sway Bar End Links (Front and Rear), IRO A-Arm Spacer, 2" Front/Rear Bumpstop Extensions
Wheels: 16x7 Cragar with 4" Backspacing
Tires: 235/85R16 BFG KM2 (32"x9")
Additional Information: Trimmed the wheel well and 1" of bumper under the fog lights - eliminated rub.
Flexing with the AT's on (same size as the KM2).
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Closed Thread
