2-3 trans shift issue - JeepForum.com
post #1 of 16 Old 04-07-2013, 04:16 PM Thread Starter
scparrish
I am having a pretty consistent issue with my trans shifting from 2nd to 3rd it won't shift unless you let off the gas and wait for it to shift it does this about 70-80% of the time any ideas I will have to go get it scanned for codes. The trans fluid is good and clean is there a solenoid or something that could be the issue? I am not familiar with the transmissions on these jeeps. thanks in advance.
mine 04 F250 Harley FX4, 90 Bronco EB 4x4
hers 99 WJ Laredo 4x4 I6 4" IRO lift with long arms
http://www.jeepforum.com/forum/f197/scparrish-build-thread-1530728/
scparrish is offline
post #2 of 16 Old 04-07-2013, 06:30 PM
car5car
2002 M-38
can be bad tps
01 XJ 2wd 4.0
car5car is offline
post #3 of 16 Old 04-07-2013, 09:52 PM Thread Starter
scparrish
That would effect a single shift nearly every time?
post #4 of 16 Old 04-09-2013, 03:45 PM Thread Starter
scparrish
anyone know the part numbers for the governor pressure sensor and solenoid?
post #5 of 16 Old 04-09-2013, 05:09 PM
86cj74.2L
86cj74.2L's Avatar
If your TPS has over 100k miles on it its worth spending the 75 dollars just because of all the things it can screw up when it starts going bad but not bad enough to code yet.
86cj74.2L is online now
post #6 of 16 Old 04-10-2013, 10:30 AM Thread Starter
scparrish
I am going to replace the tps, trans solenoid and sensor, fresh trans fluid and filter, hopefully that will help. I want to make sure this issue is resolved before it gets a lift and bigger tires and add stress to it.
post #7 of 16 Old 04-10-2013, 10:52 AM
redwolf698
Good luck with that one. Keep in mind the shifting is a CIRCUIT, which includes both mechanical and electrical components. A valve sticking in a bore is not going to be ameliorated properly through the changing of fluid and electrical component.
Daniel J Fenti
Owner - NC Transmission
2004 WJ Overland lightly modified
Boat Drinks OffRoad Co-Founder
redwolf698 is offline
post #8 of 16 Old 04-10-2013, 11:08 AM Thread Starter
scparrish
seems electrical or the valve body has an issue imo. If we were talking about a 5r110 I wouldn't be asking these questions I know where to look and what to look at. I know nothing about a 42re except what a couple suggestions say on this forum and google search.
post #9 of 16 Old 04-15-2013, 09:04 PM Thread Starter
scparrish
does anyone know where to look for a valve body rebuild or a good place to get a reman valve body after reading through a couple dozen forum and an endless amount of information and other problems everything points to a bad vb
post #10 of 16 Old 04-15-2013, 09:20 PM
js12278
Kits like this may help out with the issue
http://transmissiontechnologies.com/...-solenoid.aspx
js12278 is offline
post #11 of 16 Old 04-15-2013, 09:26 PM Thread Starter
scparrish
I have definitely been looking at those parts also since I will be taking the vb off anyways now I just need to find a rebuild kit or reman vb for a decent price.
post #12 of 16 Old 04-16-2013, 05:38 AM
86cj74.2L
86cj74.2L's Avatar
Doesn't sonnex sell on? I got one brand new with all the updates for my Saturn SL1.
post #13 of 16 Old 04-16-2013, 07:25 AM
redwolf698
Sonnax is not making one yet, but they will sell you all the reamers, tools, and parts to upgrade it.
If you want me to, I can make some calls to my suppliers and get you a price on a completed one. Email me at daniel at nctransmission dot net
Daniel J Fenti
post #14 of 16 Old 04-16-2013, 09:18 AM
drrm123
1994 ZJ
Drop pan and see what type of debris is in it before ordering parts. Might give you some insight on what is going on. There is a spring on the front servo that breaks sometimes and that could be a problem also. By dropping the pan you can tell.
2001 Jeep Grand Cherokee Laredo 6 cylinder Selectrac
$2400 installed new radiator 1 window regulator 2 oxygen sensors
drrm123 is offline
post #15 of 16 Old 04-16-2013, 11:03 AM Thread Starter
scparrish
I will drop the pan and take a look and find out if I see anything. redwolf I feel pretty confident I will be emailing you to take you up on that offer. I wish I had a lift right now because it's a tight squeeze to be underneath the jeep in stock form.
