2.0 inch lift or 2.5 inch lift for WJ - JeepForum.com
post #1 of 9 Old 05-11-2012, 10:30 AM Thread Starter
Lrw95
Wj 2.0 inch lift or 2.5 inch lift for WJ
I have a '99 jeep grand cherokee 4.0L. Its all stock right now. I want to put either a 2.0 inch or 2.5 inch lift on it. My question is which one can i do and not have to do any other adjusting? such as transfercase swap? I'd love to go 2.5 inch but if i have to adjust anything ill go 2.0.
Lrw95 is offline
post #2 of 9 Old 05-11-2012, 10:41 AM
ChrisHager
Administrator
ChrisHager's Avatar
There isn't a ton of difference between the two.
You can go cheap and install a 2" BB and new shocks and call it good...
You can upgrade a bit and install 2" springs and shocks...
To the above you CAN also add in:
Adjustable track bar and extend the sway bar end links.
For 2.5/3" all of the above is recommended.
For all of those lifts, it is a good idea to replace the spring isolators and add a new steering stabilizer.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #3 of 9 Old 05-11-2012, 10:50 AM
qbny94
Look into the 2 inch BDS lift comes with springs and new shocks. Also, has a no questions asked lifetime warranty! I just put the lift on last week and it seems like i got more than just 2 inches with the lift.. So far i love it and with any lift replace the coil isolators.
qbny94 is offline
post #4 of 9 Old 05-11-2012, 10:57 AM
BWYoung85
I would go with 2" lift springs and longer shocks and new spring isolators. It is really a matter of preference\budget and\or what your want to do with your lift (wheeling\not so much wheeling). Springs would be best for wheeling a lot. Spacers would work too, however, if you run your sway bar links disconnected, you possibly run the risk of a spring popping out. If you really want that extra 1/2" you could always add a 1/2" spacer front and rear
IMO I am looking at a 2" coil spring setup w/ longer shocks, 3/4" spacer for the front, extended link ends, and a JKS Adjustable Track bar.
If you want to look at an excellent write up on a 2" spring lift, look at this thread it features the lift mentioned *gbny94*: http://www.jeepforum.com/forum/f310/...hread-1154164/
Just remember, stacking spacers is not the wisest idea. You can run the 2" springs with a small spacer to gain what you want to achieve (2 - 3")
Hope this helps.
- 2004 Freedom Edition -I6\SelecTrac
There is a learning curve to everything.
BWYoung85 is offline
post #5 of 9 Old 05-11-2012, 08:03 PM
kc2mrg
i went with the 2.5" rusty's lift with new springs and shocks, the only thing you will have to change is if you want to keep the rear sway bar hooked up, you'll have to get longer rear links, but ive been running without mine since i put the lift on and i dont have any problems, i think it runs about $450 shipped? maybe less i dont remember, i am getting a front track bar, but you dont have too, oh and you can fit a 255/70/16 tire with no spacers and no rubbing , just found that out today
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #6 of 9 Old 05-11-2012, 09:24 PM
thisguyhasadd2
99 xj or wj.... t case swap?.... time do some reading, cant feed of the bottle forever
http://www.jeepforum.com/forum/f310/...-post-1304102/ second post
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #7 of 9 Old 05-14-2012, 11:51 AM Thread Starter
Lrw95
It's a WJ. Kc2mrg i really like your input. thaks. i think im going with a 2.5 and praying nothing goes wrong.
Lrw95 is offline
post #8 of 9 Old 05-14-2012, 01:22 PM
thisguyhasadd2
Im still on stock links at 4"
post #9 of 9 Old 05-14-2012, 05:17 PM
4Tom
I amir your honesty, you probably get flamed so let me be the first. Why ! ))
WJ 2001 3.1TD
Tom
4Tom is offline
6 inch lift with 2 inch BB 240impala WJ Grand Cherokee Forum 8 03-29-2012 11:28 PM
A 4 inch suspention lift and a 2 inch body lift. Could that suport 36inch tires? Calpatt WJ Grand Cherokee Forum 27 04-26-2011 05:17 PM
3 inch lift with 265/75/16?? XJ57 WJ Grand Cherokee Forum 21 02-21-2011 05:36 PM
4 inch teraflex lift vs IRO 4inch lift??????? anden02 WJ Grand Cherokee Forum 50 11-01-2010 10:46 AM
245/70/16 on ~3 inch lift wj_jeep92 WJ Grand Cherokee Forum 3 09-27-2010 03:43 PM
