1999 Grand Cherokee idle problem - odd - JeepForum.com
post #1 of 12 Old 08-26-2010, 06:44 PM Thread Starter
AdvisingElf
My brother-in-law bought my daughter a 1999 Grand Cherokee as a high school graduation present. It seems in great shape, but it has an odd idling issue.
When the gas tank is above half-full, it starts and idles fine. At about the half full mark you have to give it a little gas to start, and you have to keep giving it a little gas or it'll die.
I've heard that you can have problems with some cars if you don't fully crank the gas cap down, but this is just hearsay. Does the fuel pump pressurize the gas tank? It would have to work harder to pressurize a tank with more airspace in it. This is just a WAG. Anyone have any ideas?
AdvisingElf is offline
post #2 of 12 Old 09-02-2010, 05:42 PM Thread Starter
AdvisingElf
Is there anybody out there?
post #3 of 12 Old 09-02-2010, 06:38 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
There may be a problem at the tank where the fuel pump draws in fuel. I had a similar problem years ago on a vintage car and it was a fuel pickup problem due to a rusty tank. It's unlikely that your tank is rusty (since its plastic) but it may have dirt and grit in there.
The fuel tank doesn't get pressurized by the pump, but there are vacuum/emissions components drawing vapors from the intake and fuel system. If your cap is defective, it can cause a check engine light but usually won't affect running. Regardless, the cap is like $10 and they do commonly fail. It can't hurt to replace it.
WAG = Wild-*** Guess?
~Richard
billzcat1 is offline
post #4 of 12 Old 09-02-2010, 07:31 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Fuel pump is dying and has a hard time when the tank is less than half full or the strainer is plugged up on the pump. Check your fuel pressure.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #5 of 12 Old 09-02-2010, 10:04 PM
warrenpeace24
If I remember right Jeep has a TSB on this I think it was a o-ring on the fuel pump that is easily damaged
warrenpeace24 is offline
post #6 of 12 Old 09-02-2010, 10:41 PM
U2Fans
Make sure all of the vacuum lines are in place and tight... I had an idle problem on my '99 and it was due to a loose/disconnected vacuum line. It also was the culprit for my cruise control not working problem.
U2Fans is offline
post #7 of 12 Old 09-03-2010, 07:19 AM Thread Starter
AdvisingElf
Correct.
post #8 of 12 Old 09-03-2010, 07:19 AM Thread Starter
AdvisingElf
Thanks.
post #9 of 12 Old 09-03-2010, 08:47 AM
rm2001wj
rm2001wj's Avatar
With fuel injected engines, "giving it a little gas" is actually giving it a little air. Pressing on the accelerator pedal open up the throttle so that more air goes into the engine, and the engine computer controls the injectors which put in the gas. Bottom line is that you have an air problem, not a gas problem as far as the idle is concerned. Most likely the Idle Air Control (IAC) needs cleaning or replacement. Next most likely would be a worn Throttle Position Sensor (TPS). The connection with the fuel level in the tank is only a coincidence.
rm2001wj is offline
post #10 of 12 Old 09-03-2010, 10:19 AM Thread Starter
AdvisingElf
In searching for info on this problem the IAC and TPS came up. I will service those, but I doubt the fuel level thing is a coincidence. We've run it a while and it starts having trouble idling at about the half empty level, and it goes away as soon as you fill the tank. I actually hope you are right, because I don't want to have to pay to get the fuel pump replaced.
post #11 of 12 Old 09-03-2010, 10:44 AM
rm2001wj
rm2001wj's Avatar
If there was a fuel pump problem, it have to show up under conditions other than when the engine is idling. Idling requires less fuel and less effort on the part of the fuel pump than anything else, except possibly rolling down hill with no pressure on the accelerator pedal.
rm2001wj is offline
post #12 of 12 Old 04-24-2013, 11:41 AM
scottphxaz1
FYI: Today, my 99 jgc 4.0 would only start with my foot on the gas pedal, let off to idle and it would stall out. It ran perfect with my foot on the pedal. I opened the hood, wiggled the wires to the ECM, and it started and ran fine. fingers crossed
scottphxaz1 is offline
Jeep grand cherokee 1999 problem update ALEXANDER666 WJ Grand Cherokee Forum 4 09-21-2015 04:11 AM
1999 Grand Cherokee Help sgarrelts01 WJ Grand Cherokee Forum 7 10-03-2011 10:12 PM
1999 Grand Cherokee problem yubkrock WJ Grand Cherokee Forum 4 08-03-2010 06:06 PM
1999 grand cherokee (wj) caliper problem.. Jonnybigballs WJ Grand Cherokee Forum 4 07-21-2010 10:35 AM
1999 Grand Cherokee 4.7 dies tom19511 WJ Grand Cherokee Forum 8 03-26-2010 11:04 AM
