1999 Grand Cherokee AC Problem - JeepForum.com
post #1 of 7 Old 04-10-2011, 04:00 PM Thread Starter
srode
2008 XK Commander
99 Grand Cherokee Laredo with 4.7 V8, 161,000 miles - No cold air - The compressor is cycling - running for a very short period of time and then off for longer - maybe 2 seconds on and 15 seconds off, no cold air and the low side line is not cold, the high side is hot. The electric fan is running behind the radiator, the belt driven fan is coasting turning slowly at idle. I don't drive it but the wife says hot air coming out the side vents and ambient air temp coming out the center vent. I'm thinking it might be low on Freon - the AC hasn't been serivced since new - we are the original owners. Its a manual system not automatic temperature control. I have a set of gauges but don't know what the high or low side should be & I don't know what kind of Freon is in it. Can anyone tell me typical high / low side pressures, freon type and where the cut off point for pressure is supposed to be on the high and low side to kick off the compressor? Any trouble shooting tips would be greatly appreciated too!
Thanks, Steve
2008 XK Commander Limited 4.7 Quadra Trak II
1999 Jeep Grand Cherokee 4x4 Quadra Drive 4.7 L 163,000 miles(sold)
2004 GMC SLT Crew Cab 4x4 Duramax Diesel
1969 Camaro Pace Car
1969 Camaro Hard top
91 Cherokee - sold at 188,000 miles, still runing great at 250k last report
srode is offline
post #2 of 7 Old 04-10-2011, 04:25 PM
iluvtruenos
r134a, sounds like it's low.
Hook up the low/high side gauges and see if it cycles.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #3 of 7 Old 04-10-2011, 05:17 PM
HVACNY
2013 WK
If the compressor is short cycling its most likely low on gas.AC is a closed system,meaning if it worked correctly until this season then it has a leak.If its a slow leak then you can take it somewhere they can pressurize the system or put dye into the system to find the leak,fix the leak,evacuate and then charge it.Or you can keep filling it with gas and eventually kill your compressor.Its also against federal law to keep filling a system that has a known leak.People do that,i dont.The proper pressure depends on alot of factors like ambient temp,type of gas,restrictions in the system.Be carefull if you decide to diy.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #4 of 7 Old 04-10-2011, 06:30 PM
nickblack
^^^ x 2, Please take it to a qualified shop if you are not sure what you are doing, can be very dangerous. Put a new set of a/c lines and a new accumulator/drier after 12 years of use. If DIY, make sure to pressure test the system and vacuum it out completely before refilling. I changed my compressor, all hoses, accumulator and Variable Orifice line 2 years ago and refilled with freon. I don't remember what the high/low pressures were, but I do know they vary according to ambient temperature.
nickblack is offline
post #5 of 7 Old 04-10-2011, 08:47 PM Thread Starter
srode
2008 XK Commander
Is there a chart for pressures vs ambient for 134a Freon? I've worked on AC years ago when I was a mechanic, not recently.
srode is offline
post #6 of 7 Old 04-10-2011, 11:22 PM
wj0313
2003 WJ
A good High Side Pressure Reading for 134a = twice the ambient temperature + 50. For Example at 85 F, you would expect a high side pressure of 85x2=170+50 = 220 psig.
Low side should be around 30-35 lbs
wj0313 is offline
post #7 of 7 Old 04-11-2011, 04:27 AM Thread Starter
srode
2008 XK Commander
Thanks, that's what I need!
srode is offline
Jeep grand cherokee 1999 problem update ALEXANDER666 WJ Grand Cherokee Forum 4 09-21-2015 05:11 AM
1999 Grand Cherokee idle problem - odd AdvisingElf WJ Grand Cherokee Forum 11 04-24-2013 12:41 PM
Warped Front Rotor Problem - 1999 Grand Cherokee jeepmagic WJ Grand Cherokee Forum 13 09-28-2010 07:25 PM
1999 Grand Cherokee problem yubkrock WJ Grand Cherokee Forum 4 08-03-2010 07:06 PM
1999 grand cherokee (wj) caliper problem.. Jonnybigballs WJ Grand Cherokee Forum 4 07-21-2010 11:35 AM
