1999 4.0 wj 4 in Lift drive shaft and other questions - JeepForum.com
post #1 of 8 Old 08-24-2013, 01:41 PM Thread Starter
Finch1
Ok im looking for some very simple answers here.
I just picked up a very clean 1999 WJ with the 4.0l and select trac part time 4wd/Full time 4wd option. The jeep has over 230k miles. Im looking to do a 4 inch Rough Country Lift. Im on a budget.
1. The front driveshaft is the factory CV Style. I know this needs to go bye bye. IF i go to a local salvage yard what jeeps came with the style of front shafts and yokes i need to bolt on to convert it to u joint style shafts. i have the 4.0l. Factory dana 30?? Front and Dana 35 factory rear
2. Should i look at any bushings that donot come with the lift kit? If so what are common wear points on the wjs.
3. Max tire size? I have 17 in factory rubicon rims off a 2010 JK. I dont really care about flex its more of a DD then a offroad only i do plan on keeping the stock bumpers and really dont want to trim anything.
Any Help is appreciated i have found alot of mis matched opinions about stuff and i just want a simple this is what i need list thanks
Finch1 is offline
post #2 of 8 Old 08-24-2013, 03:23 PM
MuddyWJ
Budget-4" no-no. Search good sir and you'll be informed.
MuddyWJ is offline
post #3 of 8 Old 08-24-2013, 03:31 PM
mikeyc1821
yeah 4 inchs really cant be done on a "small" budget... depending on who you are and what a "small" budget is to you... i did the RC x flex 4 in, still needed a new steering stabilizer still needed upper control arms bushings... Plus a few trips to the alingment shop... all said and done with tires im about 2k in my set up...
best advice ever is to make sure that the front end is in perfect condition before you lift it
mikeyc1821 is offline
post #4 of 8 Old 08-24-2013, 07:08 PM Thread Starter
Finch1
Jeep has all new: Ball joints cvs wheel bearings tierods sway bar bushings brakes rear axle seals and bearings it has no drive line vibration and drives in a straight line
Finch1 is offline
post #5 of 8 Old 08-24-2013, 07:12 PM Thread Starter
Finch1
Maybe i should have worded that better. I work in a small repair shop. We have our own alighnment machines and what not and i can rebuild used drive shafts (hence i can use junk yard parts). I see so many posts about get v8 ones but there to short and use zjs dont use ZJs i would rather some one thats already done the swap chime in.
Finch1 is offline
post #6 of 8 Old 08-24-2013, 07:46 PM
MuddyWJ
I've done the swap! If you have an L6 a 95 or older v8 shaft will work. Warning though many yard shafts are bent due to the forks picking them up. If you have access to balancing tools and such then new tubing should be easily accessible.
MuddyWJ is offline
post #7 of 8 Old 08-24-2013, 09:22 PM
007_SuperCoupe
2015 JK Wrangler
Just did the driveshaft swap from a '94 V8 ZJ. Yard shaft ended up being bent. Make sure it's checked for trueness! Now that everything is buttoned up, it is good to go! Running 3.75-4.0" lift right now. OME HD with OME 10mm spacers.
007_SuperCoupe is offline
post #8 of 8 Old 08-24-2013, 11:51 PM Thread Starter
Finch1
Sweet. The yard i have near me picks the cars up by the doors and roofs 90% of the time lol no one knows why
Finch1 is offline
