From 14mpg to 8mpg - Page 2 - JeepForum.com
post #16 of 24 Old 06-10-2014, 07:08 AM Thread Starter
outofrng623
I am going to give it a shot because I'm curious to see if there is a running change and if fumes are actually coming out of it. My logic is it runs too much because the PCM says there is pressure but there's no pressure being released due to either the solenoid failing or a block/busted valve. The PCM may be thinking it's getting x amount of vapor when it's not. It's a starting point.
outofrng623 is offline
post #17 of 24 Old 06-10-2014, 07:10 AM
Prickett10
Keep me updated, maybe we can get to the root of the problem.
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #18 of 24 Old 06-10-2014, 07:40 AM Thread Starter
outofrng623
My top hose does not go to the tb...and the hose going to the tb is connected to a "t" of sorts. Not sure where else that going or pulling from.
post #19 of 24 Old 06-10-2014, 07:51 AM
Prickett10
Take it off of the solenoid then, should have the same effect.
post #20 of 24 Old 06-10-2014, 07:55 AM
Prickett10
Mine is a 2000 JGC And the vapor canister is under the hood. On yours I believe its back by the gas tank and the T of sort runs vapors to it so there shouldn't be an issue if you disconnect the T or pull it off the Solenoid.
post #21 of 24 Old 06-10-2014, 08:07 AM Thread Starter
outofrng623
Yeah. My solenoid is up front canister is in the back. I didn't look at the vap diagram yet. I'll pull something off today. Lol. Hose or electrical connector. But if the solenoid is stuck open pulling the connector won't do much good.
post #22 of 24 Old 06-10-2014, 09:50 AM Thread Starter
outofrng623
So. I disconnected the electrical connector. My evic is showing better mileage and it is running a tad smoother and no code about it being unplugged. I didn't like the idea of gas fumes venting into the eng compartment. I'll give it a few days to see what happens.
post #23 of 24 Old 06-10-2014, 09:56 AM
Prickett10
Two years of venting into the engine bay, and I haven't blown up yet lol.
post #24 of 24 Old 06-10-2014, 10:39 AM Thread Starter
outofrng623
I might be better off, but first I will fully insure my car.
