04 WJ won't start after running very low on fuel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 04 WJ won't start after running very low on fuel
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 05-20-2013, 04:34 PM   #1
WJay
Question 04 WJ won't start after running very low on fuel
Please help, I drove WJ home, needle almost on empty, wouldn't start next day. Cranking strong, not firing: a cough or 2 out of many tries. I can't hear fuel pump but can't swear it's not working. Forgot to mention I put 6 gal of gas in, gauge reads empty but does come up a little at ign. Should read 1/4 at least. Someone mentioned fuel system protective shutdown requiring a reset but I don't see anything about that in forum. I apologize if this is redundant, didn't have time to search all. No performance problems whatsoever prior to this (I love this Jeep)
Thanks for any advice you can give.
WJay is offline   Reply With Quote Quick reply to this message
Unread 05-20-2013, 04:56 PM   #2
Thegdog
Have you tried disconnecting the battery?
Thegdog is offline   Reply With Quote Quick reply to this message
Unread 05-20-2013, 05:40 PM   #3
79chiefs
1988 XJ Cherokee
FUEL FILTER
WHen it ran dry all the gunk in the tank would have been sucked up into the filter and clogged it.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline   Reply With Quote Quick reply to this message
Unread 05-21-2013, 05:51 AM   #4
cjcyr8
MAY have burnt out the fuel pump....I did this one time and learned my lesson...
cjcyr8 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 09:09 PM   #5
WJay
Well, fuel pump was not working, bought one at auto parts store, enlisted some help, started dropping tank and noticed complete wiring harness separated where it enters floor under back seat. Appears to have been chewed. Suspect:groundhog, maybe chipmunk, maybe field mice. Animal sanctuary policy being re-evaluated.
