'04 WJ Laredo with no fogs. - Page 2 - JeepForum.com
post #16 of 36 Old 08-14-2013, 04:12 PM
shanezoid
Yes but where is this "junction box"?
shanezoid is offline
post #17 of 36 Old 08-14-2013, 05:15 PM
rdkendrick
2003 WJ
Wherever the fog lamp relay plugs in to, it seems, going by the schematic, under the drivers-side dash:
Sent from my iPad using my fingers
rdkendrick is offline
post #18 of 36 Old 08-14-2013, 05:29 PM
cykaaro
If you look at the illustration on the fog light upgrade, there's two junction blocks by the brake pedal that they label C1/RB ( C1 right block) and they have you remove one pin from it, and add in one from the new foglight harness. It may be that it taps into that line that's needed for the fog to be powered? It just uses a common ground that's already there as well.
What does the FSM schematic show for that junction block and where does the wire you're switching go to is what has me curious.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #19 of 36 Old 08-14-2013, 06:13 PM
rdkendrick
2003 WJ
Does this help? I wish I had the higher resolution camera, but I only have the iPad2. If you need confirmation of what says what, let me know. I know it's hard to read.
post #20 of 36 Old 08-14-2013, 06:53 PM
shanezoid
Man you guys are awesome and I really appreciate it. To bad I have to work tomorrow and friday and cant do anything until saturday but I will definitely figure this one out with your help. Thanks Shane.
post #21 of 36 Old 08-14-2013, 07:53 PM
rdkendrick
2003 WJ
You're welcome. Just pass the knowledge on. I am learning a lot on here and I am trying to share what I know and have learned.
post #22 of 36 Old 08-16-2013, 08:21 PM
shanezoid
Going to try tomorrow to see if I have power in the junction box on that pin #3 and maybe run some wire!!!
post #23 of 36 Old 08-17-2013, 09:40 AM
shanezoid
I just found that the wiring in the junction box at the left firewall is there. Pin 3 when I install the relay comes on and off when I cut on the fogs but where in the hell does that wire go from there. If I can find it I can have this mastered in minutes. Help Please. Having to work in and out of the rain also which sucks!! Thanks Shane.
post #24 of 36 Old 08-17-2013, 11:25 AM
shanezoid
Am I trying to find the wire coming out of the junction in the back or the fuse part at the bottom??
post #25 of 36 Old 08-17-2013, 12:34 PM
shanezoid
Comes out of the junction box and goes into the top junction plug behind the drivers kick panel. Where from there and ideas??
post #26 of 36 Old 08-17-2013, 07:44 PM
cykaaro
If I read this right, you have power to the pin3 location when fog switch is turned on? and no power when the fog switch is turned off? once the relay is put in. Cause this makes sense in relation to the pdf install. You run your power line from the pin3 to the fogs for power, and ground it in the engine bay.
cykaaro is offline
post #27 of 36 Old 08-17-2013, 08:06 PM
cykaaro
Removed my lower dash panel to take a look at mine to see exactly what everything looks like.
As you can see, the third pin that you're supposed to take out of the junction box and tape it off is light blue. This is supposed to be replaced by the lightblue wire you brought through the firewall from the fogllight harness. Of course, making your own, you can use whatever colour you choose.
What I'm wondering is the lightblue one that you're supposed to pull out, maybe this is exactly what it is for, but since fogs lights aren't in by factory and don't have the connectors, maybe it terminates somewhere, and is why it needs to be changed out.
cykaaro is offline
post #28 of 36 Old 08-17-2013, 08:43 PM
cykaaro
Now what I'm curious about, is what are the other relays for, and what the ones not used for are. Also found a thicker light blue wire labeled electric brake while I was up underneath the dash.
cykaaro is offline
post #29 of 36 Old 08-17-2013, 09:47 PM
shanezoid
If you follow that blue wire it goes to two other connectors behind the drivers kick panel at the hood release handle. My blue wire comes in and no pin coming out and from what I can tell from there it would leave and go to the engine bay. My test light works the same in both places when I test for power. I also have that blue wire for the electric brake under mine to.
post #30 of 36 Old 08-18-2013, 12:14 PM
shanezoid
Install complete. I followed the wire to that connector and cut it and just spliced onto it instead of taking the pin out of the connector. Thanks for all the help and maybe this will help someone in the 1 per cent who dont have factory wiring.
