04 WJ electrical problem - JeepForum.com
post #1 of 12 Old 05-17-2011, 05:52 PM Thread Starter
froggo27
froggo27's Avatar
Help!!! Battery had 13V. Open door, dome light ON as usual. Turn ignition. No electrical at ignition, dome or anywhere else. I even had another vehicle jump me and the jeep ends up having electricity but has a VERY had time starting like a low battery and then it revs up and dies. I cleaned the battery terminals. I resentlly added HID bulb and i unplugged those and still nothing. Something is pulling my voltage from the battery! Any common places to check? Had battery load tested and it seemed to come out fine. Jeep will not start right now without a jump, just acts like battery is dead but it's not. AHHHHHHHHH!
Kamil
04 WJ Limited
froggo27 is offline
post #2 of 12 Old 05-17-2011, 06:02 PM
pdpunome
check your ground wires
pdpunome is offline
post #3 of 12 Old 05-17-2011, 06:03 PM
4Tom
Sounds like there is large draw on battery when not in use.
Could be faulty wire in wiring harness that goes between drivers door and body.
Is there any other strange electrical problems or glitches ?
WJ 2001 3.1TD
Tom
4Tom is offline
post #4 of 12 Old 05-17-2011, 07:04 PM
metalhead
2011 WK
Do you have an aftermarket security system? If so sometimes if not wired right it could drain battery. I would check the whole starting/charging system battery, alternator, and starter.
metalhead is offline
post #5 of 12 Old 05-17-2011, 08:30 PM Thread Starter
froggo27
froggo27's Avatar
i checked any and all visable ground. Another weird thing is that ill keep the door open for a minute and the door alarm will start ringing. As soon as i press the brake, hork the horn or turn the key the beeping stops. No aftermarket alarm
Kamil
04 WJ Limited
froggo27 is offline
post #6 of 12 Old 05-17-2011, 09:51 PM
1Silver_fox
Is the faulty door wiring a common problem? The electric door lock button on my drivers door only works when the door is open from 10 - 15 inches. And today the ignition won't start, all electrical systems and battery test fine.
1Silver_fox is offline
post #7 of 12 Old 05-17-2011, 09:56 PM
JakeWJ
yes. A wire or wires in that rubber boot are frayed or broken. easy fix
JakeWJ is offline
post #8 of 12 Old 05-17-2011, 10:09 PM Thread Starter
froggo27
froggo27's Avatar
I hope this works. I'll have to do this after work tomorow.
Read reply#6 and Reply#17:
http://autoforum.classifieds1000.com...trical_problem
Kamil
04 WJ Limited
froggo27 is offline
post #9 of 12 Old 05-18-2011, 12:36 AM
towerdude
1980 CJ7
There is a black wire in the drivers door-to-chassis boot that is a partial open. Mine just started doing it a couple of days ago too. I would have been confused but have seen all the tech talk on this prob. There are even YouTube videos showing you how to fix it. Very simple.
1980 CJ-7 Named "Wanna Bet?" - 4" RC Lift, 36" Swamper TSL's, 4.2L, and lots of character
2004 WJ Limited - "Total Eclipse" - 4" RC Lift, 265/70/17 Cooper ST's, 4.7L, Huge stereo, Roof Rack, Smittybilt 98281 XRC 8 Comp Series Black Winch with Synthetic Rope and Aluminum Fairlead mounted on reciever plate.
towerdude is offline
post #10 of 12 Old 05-18-2011, 09:30 AM
1AAdam
i will have to check my door wiring too. i have occasional electrical problems esp when it's raining.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #11 of 12 Old 05-18-2011, 01:57 PM
1Silver_fox
Found my problem. Starter contacts are worn paper thin. Installing new starter tomorrow.
I'll also fix the frayed wire in door to fix the door lock issue.
post #12 of 12 Old 05-18-2011, 07:10 PM Thread Starter
froggo27
froggo27's Avatar
well no problems at the door found.
Kamil
04 WJ Limited
froggo27 is offline
Electrical Problem jeep1987 WJ Grand Cherokee Forum 3 05-03-2011 06:38 PM
Wj Electrical Problem holyundrwr WJ Grand Cherokee Forum 13 04-24-2011 02:08 PM
Electrical Problem? MikeeN WJ Grand Cherokee Forum 1 04-19-2011 04:31 AM
Electrical Problem? WJdereck WJ Grand Cherokee Forum 3 02-09-2011 08:45 PM
WJ electrical problem mattmc74 WJ Grand Cherokee Forum 2 08-30-2010 05:35 PM
