'04 WJ Door Lock - JeepForum.com
post #1 of 8 Old 11-29-2012, 05:11 PM Thread Starter
arkieoscar
1995 XJ Cherokee
'04 WJ Door Lock
Just got this Laredo w/ 4.0. Still have my old xj with 447K miles.
Drivers door won't lock and there is a rattle in the door that sounds like a lock actuator rod. Can hear the solenoid clunk back and forth but it stays unlocked. Anyone know if there are any pitfalls to pulling the panel off and what I may need when it get it open?
arkieoscar is offline
post #2 of 8 Old 11-29-2012, 05:39 PM
Fishmoose
Should be easy fix..Pull the panel off and weather membrane and have a look.There is a big hole already cut for you..
If is the actuator itself, it's an easy fix as well.Hardest part is to get the rods on..
~4"~Bilstein 5100~BFG MUDS~Moabs~JCR Rock Sliders~Flowmaster~
Fishmoose is offline
post #3 of 8 Old 11-29-2012, 08:22 PM Thread Starter
arkieoscar
1995 XJ Cherokee
Thanks for the fast reply. I've never taken door panels off one and so I thought maybe someone who has could tell me if I'll need new fasteners and what kind of clip or whatever I may need to fix the loose hardware. Dealer is 30 miles away and I would like to get it fixed with one time of taking it apart.
post #4 of 8 Old 11-30-2012, 07:28 AM
Fishmoose
http://wjjeeps.com/doors/doorpanel.htm
post #5 of 8 Old 11-30-2012, 01:56 PM Thread Starter
arkieoscar
1995 XJ Cherokee
Thank you very much. That's just what I have been looking for. I did a search here and on google but it didn't come up with this page.
post #6 of 8 Old 11-30-2012, 02:10 PM
Schlotzky
2007 XK Commander
I would definitely buy some extra fasteners as they are quite fragile and mostly one time use. I used the P/N in the link above to purchase a box of 50 fasteners on eBay for $10. They are a bit under $6 each at the dealership, fyi.
Schlotzky is offline
post #7 of 8 Old 11-30-2012, 02:27 PM Thread Starter
arkieoscar
1995 XJ Cherokee
Thanks Schlotzky.
post #8 of 8 Old 11-30-2012, 02:35 PM
Schlotzky
2007 XK Commander
The lock actuator is connected as seen in this picture from the link:
No special tools are required. Yours either came loose, or that yellow plastic piece may be broken. I've seen those connectors on several vehicles, so it might be something you could get at an autoparts store, or if nothing else from a junk yard from most likely most Chrysler products.
