04 wj 4.7l, missfire code, check gauge light...... - JeepForum.com
post #1 of 3 Old 01-29-2014, 04:31 PM Thread Starter
thevetteguy
I ran to the store today, about 5 minutes in to the trip my check engine light came on (code 303) and check gauge light also came on, oil pressure gauge was not functioning. I was pulled into Walgreens as this happened and killed the engine. when the code came on my left turn signal also blinks 4 times faster than usual, but the right signal blinked at normal speed. I briefly looked over the engine, didn't see anything really out of place (wasn't expecting to). if I looked up the code right it says cylinder #3 misfired. when the code came on nothing felt/sounded bad. my sisters 00 WJ has a dying oil pressure sender, so I figured mine was also going bad. I jiggled the end of the sender, started the engine, and then the gauge read properly. everything sounded normal and felt fine, didn't seem as if the cylinder was still missing. I drove back home, and it all went well. not sure if it really matters, but it was also around -6 degrees, and the jeep hasn't been ran for 4 days.
so I'm almost positive the oil gauge is due to a faulty sender, but I have no idea what's /causing the misfire, and the blinker issue. has this happened to anyone else?
thanks
thevetteguy is offline
post #2 of 3 Old 01-29-2014, 04:45 PM
Duh
A fast blinker normally means low resistance-aka a blown bulb.
Oil pressure sensors are fairly common to die on the age of oir jeeps.
Misfire could be many things, but hard to diagnose without a misfire a tually happening (with no fuel injector or coil codes)
Duh is offline
post #3 of 3 Old 01-29-2014, 04:48 PM
Duh
Also, on the the oil pressure sensor, i have seen a number of times where a valve cover leak will cause oil to leak into the connector for the pressure sensor, causing the bad readings. I have also seen the sensor itself leak.
Duh is offline
