04 key fobs ??? - JeepForum.com
post #1 of 22 Old 03-01-2012, 07:58 PM Thread Starter
skiebuster
04 key fobs ???
I have 2 2004 Grand Cherokees
one is a 4.0, other is a 4.7
within a week, both fobs for each GC stopped working.
I replaced the batteries in the 4.0....did not help nor does it unlock or lock.
I havent replaced the 4.7's yet but will later this weekend.
I was told by auto zone that the antenna could be messed up in my 4.0
antenna? where would that be located? and how do I fix?
skiebuster is offline
post #2 of 22 Old 03-01-2012, 08:04 PM
BLACK04WJ
I'm not sure where it would be but I'm going to watch this thread.. I also have 2 2004 grand Cherokees one 4.0 and one 4.7 and don't know when mine will do the same thing.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #3 of 22 Old 03-01-2012, 08:58 PM Thread Starter
skiebuster
this really sucks....
I am hoping my wires 4.7 needs batteries only.
The 4.0 is a Freedom and wondering how in the world to fix this..
post #4 of 22 Old 03-01-2012, 09:09 PM
lafacej
There isn't really an antenna in the fob but the antenna in the keyless entry receiver is located in the passenger side door by the window module. It should have a single wire coming out of it and that's the antenna. If you make it bigger you can get a better signal. I had the same prob.
lafacej is offline
post #5 of 22 Old 03-02-2012, 11:23 AM
kerno
The keyless entry module is attached to the inside of the right door panel and is a black plastic box about 5 inches long.
kerno is offline
post #6 of 22 Old 03-02-2012, 11:27 AM
nhcd538
nhcd538's Avatar
Having the same issue here on my 04...replaced batteries in my fob with two brand new, fresh ones and it will only lock or unlock if you're standing within a foot of the passenger front door. Odd.
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #7 of 22 Old 03-02-2012, 12:00 PM
jayward
mines been acting up too, but i figured it was just time to replace the batteries.... hope i don't have the same trouble... if i'm remembering.... it seems to unlock fine, but lock can be weird....
jayward is offline
post #8 of 22 Old 03-02-2012, 01:36 PM
berndog67
2003 WJ
so what is the length of the stock antenna, how long have u made it to get better range, and did u just solder on more wire or replace it entirely with a new longer wire
berndog67 is offline
post #9 of 22 Old 03-04-2012, 01:18 PM Thread Starter
skiebuster
how did you make the antenna bigger? what wire did you use?
post #10 of 22 Old 03-04-2012, 06:23 PM
sfjacks1
this may sound silly, did you check the ground wires inside the boots between the jeep and the door, i know it sounds crazy, but what if both ground wires in the d.s. and p.s. broke...i think that would cause the same issue
..good luck
sfjacks1 is offline
post #11 of 22 Old 03-06-2012, 06:28 PM
HVACNY
2013 WK
Anything?you may have to sync your fobs again.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #12 of 22 Old 03-06-2012, 06:35 PM
BLACK04WJ
I shouldn't have said anything on this post! my wife's isn't workin now on her 2004 4.0.. how hard is it to fix the antenna? it only works a foot away from the passenger door
Oct '12 GCOTM
post #13 of 22 Old 03-06-2012, 06:43 PM
HVACNY
2013 WK
Couldnt leave well enough alone,lol..A bad antenna is doubtfull for yours,mine did the same as yours right before the batteries died,it takes 2 (2016) coin batteries by the way.
HVACNY is offline
post #14 of 22 Old 03-06-2012, 06:48 PM
BLACK04WJ
haha no I couldn't! alright I will try that tonight and see if it works. thanks!
Oct '12 GCOTM
post #15 of 22 Old 03-06-2012, 09:01 PM
lafacej
I soldered a new wire on. Just a stripped down 16 gauge wire I had laying around I think. Made it come all the way up to the weather stripping in the door. My antenna was almost broke off which was why I had bad range
lafacej is offline
key fobs tbone1004 WJ Grand Cherokee Forum 2 12-16-2011 11:52 AM
