-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   04 key fobs ??? (http://www.jeepforum.com/forum/f310/04-key-fobs-1336829/)
skiebuster 03-01-2012 07:58 PM
04 key fobs ???
I have 2 2004 Grand Cherokees
one is a 4.0, other is a 4.7
within a week, both fobs for each GC stopped working.
I replaced the batteries in the 4.0....did not help nor does it unlock or lock.
I havent replaced the 4.7's yet but will later this weekend.
I was told by auto zone that the antenna could be messed up in my 4.0
antenna? where would that be located? and how do I fix?
BLACK04WJ 03-01-2012 08:04 PM
I'm not sure where it would be but I'm going to watch this thread.. I also have 2 2004 grand Cherokees one 4.0 and one 4.7 and don't know when mine will do the same thing.
skiebuster 03-01-2012 08:58 PM
this really sucks....
I am hoping my wires 4.7 needs batteries only.
The 4.0 is a Freedom and wondering how in the world to fix this..
lafacej 03-01-2012 09:09 PM
There isn't really an antenna in the fob but the antenna in the keyless entry receiver is located in the passenger side door by the window module. It should have a single wire coming out of it and that's the antenna. If you make it bigger you can get a better signal. I had the same prob.
kerno 03-02-2012 11:23 AM
The keyless entry module is attached to the inside of the right door panel and is a black plastic box about 5 inches long.
nhcd538 03-02-2012 11:27 AM
Having the same issue here on my 04...replaced batteries in my fob with two brand new, fresh ones and it will only lock or unlock if you're standing within a foot of the passenger front door. Odd.
jayward 03-02-2012 12:00 PM
mines been acting up too, but i figured it was just time to replace the batteries.... hope i don't have the same trouble... if i'm remembering.... it seems to unlock fine, but lock can be weird....
berndog67 03-02-2012 01:36 PM
so what is the length of the stock antenna, how long have u made it to get better range, and did u just solder on more wire or replace it entirely with a new longer wire
skiebuster 03-04-2012 01:18 PM
how did you make the antenna bigger? what wire did you use?
sfjacks1 03-04-2012 06:23 PM
this may sound silly, did you check the ground wires inside the boots between the jeep and the door, i know it sounds crazy, but what if both ground wires in the d.s. and p.s. broke...i think that would cause the same issue
..good luck
HVACNY 03-06-2012 06:28 PM
Anything?you may have to sync your fobs again.
BLACK04WJ 03-06-2012 06:35 PM
I shouldn't have said anything on this post! my wife's isn't workin now on her 2004 4.0.. how hard is it to fix the antenna? it only works a foot away from the passenger door
HVACNY 03-06-2012 06:43 PM
Couldnt leave well enough alone,lol..A bad antenna is doubtfull for yours,mine did the same as yours right before the batteries died,it takes 2 (2016) coin batteries by the way.
BLACK04WJ 03-06-2012 06:48 PM
haha no I couldn't! alright I will try that tonight and see if it works. thanks!
lafacej 03-06-2012 09:01 PM
I soldered a new wire on. Just a stripped down 16 gauge wire I had laying around I think. Made it come all the way up to the weather stripping in the door. My antenna was almost broke off which was why I had bad range
The time now is 04:24 PM.
