04 jeep grand cherokee just dies - Page 6 - JeepForum.com
post #76 of 79 Old 02-25-2014, 11:15 AM
jbeez
my wj stalls that way but only when it gets down to a hair under 3/4 tank. never fails to stall at that range.
jbeez is offline
post #77 of 79 Old 02-25-2014, 11:33 AM
soonerdg
2003 WJ
I second the crank shaft sensor. My son was recently having the e act same issue and it was the crank shaft sensor.
soonerdg is offline
post #78 of 79 Old 02-25-2014, 11:48 AM
grussell
I had the same symptoms a few months ago and it turned out to be the fuel pump. Some days it worked with no problems, the next day the GC would die and not restart. There was no consistent pattern. I spent a lot of time diagnosing everything. I replaced the fuel pump and have not had a problems since. When it will not start, have you tried turning on the ignition and listening for the fuel pump pressurizing the system?
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #79 of 79 Old 04-07-2016, 04:52 PM
kaima1
Originally Posted by MichaelS75 View Post
My 4.7 was experiencing the same exact issues. Turned out to be the plastic connector to the map sensor was broken which caused voltage issues. After taping it up really good and replacing the wiring, all is well again. I would HIGHLY recommend inspecting the wiring and such going to it before replacing the sensor itself.
I used a 25 or 20 torx bit, not sure which, and a 6 inch extension and slowly got it out with a ratchet. Be very careful and don't lose the screws like I did lol
what did you remove??? its virtually impossible from the front or top? what screws did u replace it with?
kaima1 is offline
