04 Grand Cherokee Off Road Light Install - JeepForum.com
post #1 of 20 Old 06-13-2011, 06:29 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I was on here a week or two ago and saw someone had posted up a link for off road lights at a discounted rate from harbor freight. So I went and bought two sets of them. Here is the final product:
I'll try to do a bit of a write up for everyone interested. This idea started out when I installed my tow hooks. I was told that I would be able to strengthen the tow hooks a bit if I ran a steel plate between the two:
Right Tow Hook Bolt:
Left Tow Hook Bolt:
So I bought:
I cut this to 22 3/4" and drilled the holes at 21 1/4" on center. (If you do this, please double check my measurements before you start)
For two of the mounting tabs, I used:
I cut them to 7".
I drilled holes in both sides of the 7" tabs. I also drilled a hole in each side of the main support bar to mount the two outside lights and two holes towards the middle to mount the lower inner lights. I can't remember where exactly I drilled the holes as I was getting tired and forgot to take pictures. Just eyeball it and then measure in equally for each side.
So now I have a main support bar with 6 holes: 2 to mount to the jeep and 4 to mount the lights. I mounted the two 7 inch tabs with I believe 2.5 inch bolts and used washers to space out the width as to not hit the bumper with the tabs. The lower inner two lights I mounted straight to the main support with a few washers as spacers. When I had everything set and test fitted, I took it all apart, scuffed all the metal with a grinder, primed, and painted to avoid rust.
Put it all back together and mounted them up (sorry for the quality):
The red arrow shows where the middle light mounts to the bar. The green arrow shows how the 7" tab mounts to the main support bar. The blue arrow shows the main support bar mounted to the tow hook/tow hook mounting plate. So now I have a little extra support on the tow hooks and a light bar with no modification to the vehicle.
I was able to run all the wires through the firewall(?) and mounted the two switches under the dash on a little hidden plastic strip. This worked well as it's out of sight yet still easy to get to.
Interesting Saturday project but pretty easy really. This could be done much more advanced with welding and such (which I may eventually do when I get time) but it demonstrates what you can make with a few simple tools and some patience. They are quite sturdy and can be undone very easily with no marks or holes in the body as well which is nice.
Let me know what you think or if you want any more pictures. If people are interested, I could probably pop it off one afternoon and take a picture of the whole mounting assembly with the lights attached.
Chris
ChrisHager is offline
post #2 of 20 Old 06-13-2011, 07:10 PM
gcjeeping
gcjeeping's Avatar
If you do any kind of wheeling dont think those bottom ones are gunna last too long. I had a set there years ago. They lasted 3 weeks and one rock.
gcjeeping is offline
post #3 of 20 Old 06-13-2011, 07:14 PM
wyattrhicks
Hey Man! link those lights im intrested
/JeepBoy/
wyattrhicks is offline
post #4 of 20 Old 06-13-2011, 07:31 PM
JeepWJ26
Can you put up a daytime shot from the front. I already have the lights, just not sure when I want to mount them. Was originally going to fab up a light bar for across the top, but I think these lights are a little too big and it doesnt look that good.
2002 Jeep Grand Cherokee Laredo >> "Johnny Cash Jeep." -- 2.5" Old Man Emu coil spring lift -- Rancho 5000 series shocks -- Custom subwoofer set-up
“Johnny Cash Jeep” Build > http://www.jeepforum.com/forum/f22/jeepwj26-build-johnny-cash-build-1210835/
JeepWJ26 is offline
post #5 of 20 Old 06-13-2011, 07:36 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Here is the link for the lights:
http://www.harborfreight.com/off-roa...stem-3029.html
Yeah I imagine I'll snap one off someday but for the price I got them at, definitely worth it even if they only last me a month. I think both sets, extra wire, and all the metal/hardware cost me less than a tank of gas. Plus now I have mounting points for some more durable ones in the future if I find I break these too quickly.
post #6 of 20 Old 06-13-2011, 07:38 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
And yeah I'll take a picture in the morning before I leave for work and hopefully get it uploaded around lunch.
post #7 of 20 Old 06-13-2011, 09:35 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I had a set of those, not bad for $20. However, they are really a tight long-range spot pattern, the adjusters are hard to set as they are notched, and overall I didn't find them that useful. Also, with the grid on the front that is not removable, it's hard to get mud out of them. The $60 Hella 500s are three times as expensive but worth every penny.
~Richard
billzcat1 is offline
post #8 of 20 Old 06-14-2011, 08:25 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Yeah I too noticed how direct of a spot they are. They don't seem too difficult to adjust but then again, I've never worked with nice lights. Haha. They may have made changes to these lights since you last had them. The ones I have have removable front pieces for cleaning and bulb replacement purposes...
Sorry I haven't taken a front pic yet... It has been raining all day...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
post #9 of 20 Old 06-14-2011, 09:43 AM
billzcat1
2003 WJ
The ones I had look identical, but you have to completely diassemble them to change bulbs or clean behind the mesh lens guard.
~Richard
post #10 of 20 Old 06-23-2011, 08:36 PM
JeepWJ26
Any day time pictures? I went out and bought 2, but I think I may get another set, just trying to get an idea of where to mount them.
JeepWJ26 is offline
post #11 of 20 Old 06-24-2011, 08:30 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Sorry I haven't gotten that up until now. I think this will work for ya. Let me know if you need anymore!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 20 Old 06-24-2011, 07:32 PM
justn
Could you get a pic of where you have your switch placed?
justn is offline
post #13 of 20 Old 06-26-2011, 03:12 PM
JeepWJ26
Thanks man, looks great. I may be doing the same thing.
JeepWJ26 is offline
post #14 of 20 Old 06-26-2011, 04:05 PM
Thomahawk
That's a sweet setup. Thumbsup!
Buildthread
Thomahawk is offline
post #15 of 20 Old 06-27-2011, 07:17 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Thanks for compliments. Here is a picture of the switches. If you look up under there, there is a nice piece of plastic you can attach the switches to.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
2002 grand cherokee Shifter light atomb WJ Grand Cherokee Forum 24 01-14-2014 09:18 AM
2002 Jeep Grand Cherokee/OVER TEMP LIGHT ON pjohn WJ Grand Cherokee Forum 10 08-09-2013 10:50 AM
2002 Grand Cherokee road handling query - UK mumof3 WJ Grand Cherokee Forum 22 03-31-2011 02:00 AM
04 Grand Cherokee, misfiring, check engine light P0201 djx2005 WJ Grand Cherokee Forum 2 08-24-2010 04:17 PM
MIL light came on in my 2001 Jeep Grand Cherokee 37K miles Hunter1123 WJ Grand Cherokee Forum 7 05-24-2004 05:15 PM
