04 grand cherokee - JeepForum.com
post #1 of 10 Old 10-30-2013, 09:46 PM Thread Starter
gloomis1988
04 grand cherokee
4.0 rear main seal leak so will be replacing the oil pan gasket as well the main ? is do I need to disconnect the transmission to get to the rear main seal
gloomis1988 is offline
post #2 of 10 Old 10-30-2013, 10:37 PM
88yjproject
Drop oil pan, no need to pull transmission out.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #3 of 10 Old 10-31-2013, 06:04 AM
Duh
Pull oil pan, pull bearing brace. Pull six bearing cap. Half of the seal slides up into a hole above the cap, the other half is settled into the cap . Dont tear the top half when putting it in, very easy to do.
Duh is offline
post #4 of 10 Old 10-31-2013, 06:24 AM Thread Starter
gloomis1988
Thanks guys
post #5 of 10 Old 10-31-2013, 07:02 AM
briandor
Wear goggles. Oil in the eyes sucks.
briandor is offline
post #6 of 10 Old 10-31-2013, 09:04 AM
Rough Country
Vendor
Rough Country's Avatar
This. Sucks very bad lol
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
  • 731-288-6803
Rough Country is offline
post #7 of 10 Old 10-31-2013, 11:32 AM
jpat30
You Tube It; there are several good videos on the subject that include some tricks such as when you get started throw your new seal in a cup of oil and let it soak til you are ready to use. It will absorb oil and provide for a better seal upon start up. Not a bad job, just takes a while. Good Luck and be patient and it will work out.
-Carpe Diem Phil 1:20
jpat30 is offline
post #8 of 10 Old 11-09-2013, 05:13 PM Thread Starter
gloomis1988
Okay put my rear main seal but forgot the bolt pattern on my oil pan and does anyone know the torque spec on the bearing caps
post #9 of 10 Old 11-09-2013, 05:59 PM
Duh
85 ft lbs on cap and 35 ft lbs on brace sticks in my head but im not positive without looking it. back up. As far as bolt pattern, just start in the middle and sig zag back and forth towards the ends-its normal practice.
Duh is offline
post #10 of 10 Old 11-10-2013, 07:18 AM Thread Starter
gloomis1988
I looked up the bolt pattern but my thing is I forgot what bolts go where sense there three different bolts any have a pic of there oil pan they can take for me please hoping I can finish her up today after work
