04 GC Key/Chip Problems? - JeepForum.com
post #1 of 3 Old 02-04-2014, 05:47 AM Thread Starter
joetad
2003 WJ
My 2004 Jeep GC recently popped up with a dead battery. While trying to jump it and bring it back to life I had the following problem:
She would start normally but some sort of Auto-disable feature would engage after 3 seconds. Every single time. No problem starting and it would idle fine, then at 3 seconds it would just die. I would see the "No Key" lamp illuminated on the dash after it dies each time.
I researched the problem and several people mentioned that the chip/id in the key can go bad and cause this problem.
I have 2 sets of keys and tried both of them.....each with the same result.
There's no way both of my keys "deprogrammed" or went bad at exactly the same time. Is there? Is there some sort of reset for the Jeep or do I really just need to have both my keys reprogrammed?
Wondering if anyone else had ever encountered this problem and if there is a fix? I would really prefer not to have it towed to a dealership and pay an arm and a leg to get this fixed.
Thanks for your help.
joetad is offline
post #2 of 3 Old 02-06-2014, 08:27 AM
apstang50
Junior Member
My guess is that you may have an issue with the SKIM and not the keys.
apstang50 is offline
post #3 of 3 Old 02-07-2014, 03:55 AM
86cj74.2L
86cj74.2L's Avatar
I'm with the SKIM module being bad.
I also don't think a key can deprogram. At least not a factory key. The aftermarket keys made to mimic a factory keys transponder code yes......
I haven't smashed a factory security key yet but when I run across one in the junkyard I want to. What I expect to find is a gridwork in the key. And the skim module sends a high frequency pulse and the key takes that pulse and reflects it back altered slightly.
But I could be wrong. But generally if it was battery powered they only last around 10 years. How many of you all have tire pressure monitors going dead now?
86cj74.2L is offline
