04 & 99 WJ questions... - JeepForum.com
post #1 of 5 Old 08-06-2011, 02:22 PM Thread Starter
skiebuster
04 4.0 Laredo first...180k everything is tight and I have kept up on maintenance etc.
Heres what its doing...driving down why at 60-70 mph and let off gas and tap the throttle, read feels loose. Its swaying back n forth. Take off hard etc, no sway. I checked the trailing arms and the upper wishbone and everything checks out ok. Driveshaft isn't lose. Front end is tight. I just replace the steering joints last month. New tranny mount and the motor mounts check out ok. This rear sway has been going on for 2 months now, I can not figure this out! arghhhh
Now for the 99...4.7v8 Wont start, POURING out water through the exhaust. With the radiator cap off, it will shoot water out while cranking. No water in the oil.
Cranks, doesn't fire. While cranking, I hear a major squeak coming from the upper intake area. Any ideas?
skiebuster is offline
post #2 of 5 Old 08-06-2011, 03:10 PM
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Is it possible that you have a blowout somewhere on the head gasket that's allowing water out the exhaust and pressure from the combustion chamber into the cooling system, yet the piston rings are still tight enough to apparently keep water from making its way into the lower engine.
I cannot imagine any other way that water would "pour" from the exhaust and "shoot" from the radiator while cranking without starting.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
post #3 of 5 Old 08-06-2011, 03:28 PM
tbone1004
check your rear sway bar and end links on the 04
tbone1004 is offline
post #4 of 5 Old 08-06-2011, 08:35 PM Thread Starter
skiebuster
thats what I been thinking , I really am looking forward to taking it apart and seeing what is wrong. You want to help me????
post #5 of 5 Old 08-06-2011, 08:36 PM Thread Starter
skiebuster
that i didn't do. Thanks and will get on it tomorrow!
ecm questions cstiles WJ Grand Cherokee Forum 5 03-05-2011 11:36 AM
new guy here with some questions vwbuge WJ Grand Cherokee Forum 1 03-02-2011 09:29 AM
Modification Questions and Maintenance Questions. lilZeus WJ Grand Cherokee Forum 26 10-28-2010 10:50 AM
A few questions on an 00 dub. BrianBSHS WJ Grand Cherokee Forum 22 09-23-2010 07:51 PM
I have 3 questions? ljhopp WJ Grand Cherokee Forum 7 08-25-2010 10:40 PM
