04 4.0 bleeding coolant - JeepForum.com
post #1 of 6 Old 07-11-2013, 07:21 PM Thread Starter
Krom
04 4.0 with 140k miles
Was under the jeep tonight changing out an o2 sensor (turns out I need a pigtail as a wire is broken right next to the connector on the harness side :banghead: ) when I noticed a few red drops on the front edge of the oil pan . Can't see the water pump weep hole, but noticed some red crusty stuff growing out the side of the thermostat housing...
How common is it for the housing to leak on these?
I'm prob going to replace the pump anyway, and do a flush (even though I hate taking off good parts) any recommendations for brands of punp that are good, or to stay away from?
Krom is offline
post #2 of 6 Old 07-15-2013, 06:38 AM
Buddha_Kip
Buddha_Kip's Avatar
red? sure it isn't tranny fluid? your tranny cooler lines go by there.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #3 of 6 Old 07-15-2013, 06:48 AM
doityourselfMM
doityourselfMM's Avatar
The water pump weep hole is on the underside of the pump housing, pretty close to the shaft. I could not see mine, until I removed the water pump.
The red you see could also be HOAT coolant, which is generally red in color. That is the spec-ed coolant for the '04. When I replaced my water pump, I also replaced the thermostat, the thermostat housing and gasket. Since I hate draining the system and spending money on coolant, I figured I would do it all at the same time. Actually, I also replaced the two radiator hoses and heater hoses while I was at it. And, the hard pipe that screws into the water pump.
doityourselfMM is offline
post #4 of 6 Old 07-15-2013, 10:36 AM
Brakeman62
X2. I did the same to mine.
Brakeman62 is offline
post #5 of 6 Old 07-15-2013, 10:37 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Did it smell sweet or like death?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 6 Old 07-15-2013, 04:53 PM Thread Starter
Krom
its definitely coolant. I was surprised to see it growing a red crystal out the side of the thermostat housing though.
Krom is offline
