03-13-2010, 01:31 PM
#1
03wj pinion angle adjustment
03wj pinion angle adjustment. where do i read it with the protractor level? in otherwords where do i stick the magnetic level? and it is adjusted by the upper control arm on the drivers side right? ron
[B][/B][SIZE="1"][B]aussie[/B] rear end, drilled and slotted rotors, ceramic brake pads, [B]ironman[/B] adj.front upper/lower and rear lower control arms, [B]teraflex [/B]4" spring lift, [B]fat bobs[/B] 2' bb, [B]rusty's[/B] drop pitman arm, [B]jks[/B] adjustable trackbar, [B]moog[/B] tie rod ends/ball joints, [B]rancho 9000[/B] shocks, [B]kor[/B] dual stabilizer, [B]rough country[/B] front and rear bump stop extensions, homebrew front quick disconnects, [B]rough country[/B] rear swaybar link drop kit, [B]IRO[/B] a-arm spacer, transfer case drop kit, homebrew rocksliders, [B]rola[/B] roof rack, [B]speed bleeders[/B], 2" wheel spacers, 4-[B]treadwright[/B] guard dog mt 265/75/16, mud flaps, [B]superchip[/B], [B]k&n[/B] cold air intake, straightpiped, chrome tailpipe tip,[B] v-led[/B] hid headlights w/halo,[B] v-led [/B]hid foglights w/halo, [B]kidde[/B] fire extinguisher w/bracket, [B]maglite[/B] w/mounting bracket, [B]cobra[/B] cb, [B]firestik[/B] antenna, [B]white gauges[/B] gauge face overlays, [B]viair[/B] compressor, blue led interior lighting upgrade, [B]hi lift[/B] 48" jack, [B]hi lift[/B] jack base, wind deflectors for: hood, moon roof and windows, [B]sony[/B] stereo, [B]garmin[/B] nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, [B]cobra[/B] radar detector, [B]smittybilt[/B] gear seat covers and tailgate organizer, [B]browning[/B] rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, [B]addco[/B] rear swaybar, deer whistles, [B]mobile one[/B] synthetic oil, [B]slick 50[/B] high mileage oil additive, [B]k&n[/B] oil filter
[B]TO DO:[/B]
[B]reece[/B] front hitch, [B]warn[/B] winch, [B]elocker [/B]or [B]arb[/B] front selectable locker, [B]bulldog[/B] remote start, [B]hi lift[/B] essential parts kit, 2-[B]hella[/B] driving lights, [B]gerry[/B] can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, [B]addco [/B]front swaybar[/SIZE]
03-13-2010, 03:09 PM
#2
if it has a standard u joint then simply compare the angle of the driveshaft to the angle of the yoke. Ideally you want the difference between them about zero. All you should care about is the difference between the two readings and it should be zero or only 1 degree difference.
Find a flat spot on the driveshaft to get a reading
then put a decent sized socket on the end cap of the u joint side of the diff yoke. make sure it sits flat on the cap, only on the cap and is pointing straight down. put the gauge on the socket to get a reading. That one is a little tricky as it wants to rock a little. When you do it you will see.
Some people want to bias the reading since the yoke wants to drop under power. Also if a lot of weight gets in the jeep it changes the angle.
03-13-2010, 04:49 PM
#3
2004 Overland 4.7L HO 4" Teraflex coils, IRO front long arms and rear adj control arms, 32" Goodyear Duratracs
1975 CJ5 Glass tub, AMC 304, Holley TA 470, D.U.I. distributer, 33" Goodyear MTRs
03-14-2010, 11:18 AM
#4
Originally Posted by Chadicus
these are great!!!! i printed both of them off and am on my way to the garage to finish the job. thanks
[B]TO DO:[/B]
05-15-2010, 07:29 PM
#5
Addicted to my Jeep
excellent articles... this will help with my issues
Erik
98 ZJ 5.2L JGC Limited Sold 02 4.7L HO JGC Overland
