03wj front driveshaft spinning in 2hi. is this normal? help!! - JeepForum.com
post #1 of 20 Old 06-21-2010, 11:22 PM Thread Starter
ronsaun
2003 WJ
03wj i have a 242 selectrac. my front driveshaft is spinning in 2hi. is this normal? if not that would explain why i have blown my front differential, combined with putting some miles on it with an exaggerated pinion angle. i fixed the pinion angle 2 weeks ago but i may have already killed my pinion bearings. so much for wheeling in the rocky mountains the rest of the week. this really sucks. the upside is i get to rebuild my front diff with a locker! yea! also, i can rebuild my t case and make it bullet proof. AND, i will get to buy some new craftsman tools. i love looking on the bright side. ron
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #2 of 20 Old 06-21-2010, 11:57 PM
ZJ5point2GCL
the front drive shaft always spins no matter what transfer-case mode its in, when in 2wd the front wheels turn it while they spin. its not like fords with locking hubs.
so go ahead on go wheeling. Have fun.
alos how long were you running with a bad pinion angle? and how bad?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #3 of 20 Old 06-22-2010, 02:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Is it spinning with tires off the ground or did you just notice that every part of the driveline spins when you're moving?
ratmonkey is offline
post #4 of 20 Old 06-22-2010, 05:10 AM
FirefightinWJ
Are you planning on rebuilding your front dif yourself?
If so, you may want to rethink that. It is a job that requires an assortment of specialty tools, and is a job that if you even slightly install something wrong, you will be back to square one buying a new R&P and master install kit.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #5 of 20 Old 06-22-2010, 05:51 AM
sadass
2x on the , Its normal operation for the front D.S to rotate in 2h while rolling down the road.
Aussies all the way around, Nice! you will love it. As far as the 242, I would just keep and eye on the fluid level and when you are locked front and rear try to wheel with it in full time 4x4 as much as possible until you really need to lock the case Up for extra traction. (Part time 4x4, and 4.low is locked) When In full time it acts like and open diff axle, much less stress on the case is what I Am thinking , and I know there is less binding on turns off road when locked front and rear. But as far as 242 upgrades, I do not know. I did get a new chain before the install on mine.
My 242 has held up well with 33's locked F/R and the 5.9
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #6 of 20 Old 06-22-2010, 07:11 PM Thread Starter
ronsaun
2003 WJ
it spins when in 2hi when up on jackstands. so i am assuming something is wrong. i only asked to confirm that there were no clutches or something that made that situation normal. i just rebuilt my rear end and everything turned out fine. i just replaced both pinion bearings and the trick was to reuse the original crush sleeve and spacers. i was lucky though because i didnt have to do the gears. thanks, ron
TO DO:
ronsaun is offline
post #7 of 20 Old 06-22-2010, 07:14 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
NEVER reuse the crush sleeve.
post #8 of 20 Old 06-22-2010, 07:20 PM
JesseOR
Beat me to it!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #9 of 20 Old 06-22-2010, 08:19 PM
StrokedWJ
StrokedWJ's Avatar
If the driveshaft is spinning and the wheels aren't moving then yes something is wrong. If I had to guess, I'd think it was the spider gears...but it could also be the ring or pinion. Pop the cover and report back.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #10 of 20 Old 06-22-2010, 08:48 PM
WiCkeDuDe
There are no hubs on a WJ so of course the driveshaft has to turn. If it didnt you have trouble. Im with everyone else on the crush sleeve. Be prepared for your pinion to loosen up and it will start making lots of noises down the road.
NEVER reuse a crush sleeve. Even if its new and slightly overcrushed. Get another.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #11 of 20 Old 06-22-2010, 09:41 PM
jamnjeep
if you are on jackstands and the frt ds is spinning in 2wd, then yes I would say you have to have a tc issue. But the frt ds is always going to spin if the frt tires are turning.
Maybe your linkage is out of adjustment?? you are actually in 4wheel partime while your shifter is reading 2hi.
good luck
1994 YJ under construction....
jamnjeep is offline
post #12 of 20 Old 06-22-2010, 10:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Hed know it on the road if it was in part time. Unless he broke the front diff because of it already.
If the resistance in the front driveline is low enough I could see the shaft dragging the front output along at a slower rpm than the rear if you're getting on it. It will drag the output along with no driveshaft in the front.
post #13 of 20 Old 06-22-2010, 11:20 PM Thread Starter
ronsaun
2003 WJ
well, i took the front ds out. the rattling is gone and i found where the rear pinion bearing is shot. that was causing the rattling that brought this all to light. also, i drove 160 miles and rechecked my mileage vs. with the front drive shaft in and i was getting only 12.8. now i am getting 17.5 which all but certainly confirms a transfer case issue!!! it had been in 4wd for 3000k. that explains about $1000 for gas so far and still have 3 days vacation and 1800 miles to go. ron
TO DO:
ronsaun is offline
post #14 of 20 Old 06-23-2010, 12:27 AM
ZJ5point2GCL
was it dragging/ hopping in turns? i find it hard to believe that for 3000 miles you didn't notice that it was in 4x
when it was on jack stands did the front wheels turn too?
post #15 of 20 Old 06-23-2010, 02:25 AM
xJoshxx
2012 WK
Poor Ron Pretty soon you'll have a new jeep won't you?
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
03wj lots of front/rear movement in park? ronsaun ZJ Grand Cherokee Forum 2 04-17-2010 05:29 PM
03wj cant stand front tow hooks. what to do? ronsaun WJ Grand Cherokee Forum 26 04-05-2010 09:15 AM
03wj setting up front control arm problems.help!!!!!!!!! ronsaun WJ Grand Cherokee Forum 29 03-14-2010 02:28 PM
03wj sway in the front end. why? help! ronsaun ZJ Grand Cherokee Forum 28 02-26-2010 10:25 PM
03wj i have an electric fan!! is this normal? ronsaun ZJ Grand Cherokee Forum 22 02-24-2010 01:24 AM
