03' cherokee Limited, p0351, p0352 - JeepForum.com
post #1 of 2 Old 03-30-2010, 08:13 PM Thread Starter
DjRoulette
2003 XJ Cherokee
At first I had problems with the Jeep Cherokee Limited 2wd, it was stalling and running horrible. I decided to replace the Crankshaft Sensor, while replacing this sensor I found a broken vacuum tube. Replaced vacuum tube and sensor put the jeep back together and now I receive p0351, p0352, codes and the jeep starts fine idles good but when I press the gas pedal it feels like a miss fire. I have checked everything I removed and made sure it was put back together properly. All sensors are plugged in and fuel injectors. Any suggestions
DjRoulette is offline
post #2 of 2 Old 03-30-2010, 08:13 PM Thread Starter
DjRoulette
2003 XJ Cherokee
After searching for countless hours, I have discovered that I unscrewed a sensor I shouldn't have, the camshaft sensor and oil pump drive. I did not unscrew the 2 smaller bolts, I unscrewed the 1 larger bolt holding the entire assembly in. I removed it along with the bracket holding it. checked for resistance with voltage meter, thinking it was the crankshaft sensor. I did make note of how it was put in, with the wire harness facing firewall. I do remember it spinning.
Here is my question How do I set the engine to Top Dead Center (TDC) and what else do I need to do to fix this. I read about the toothpick and aligning the holes, but the post that I am assuming is a Do It Yourself to replace the oil pump drive underneath the sensor, had alot of initials. So my other questions where are the timing marks? What is a DRB and when I figure out how to get the engine to TDC, whick way do I turn the engine.
The only type of timing experience I have was on a Dunebuggy I built for playtime!!! I would turn the largest pulley using a socket and breaker bar.
Help! OBDII code P0351...x2 rooster51 ZJ Grand Cherokee Forum 82 11-17-2016 06:00 PM
5.9 GC Limited vs 4.0 GC or Cherokee Curt941 ZJ Grand Cherokee Forum 2 06-24-2008 07:27 AM
Check Engine Light P0351 debbie9339 ZJ Grand Cherokee Forum 1 07-23-2007 08:50 AM
P0351 Frustration Terry Albritton ZJ Grand Cherokee Forum 4 10-01-2005 04:45 PM
trading GC Limited for cherokee limited stant52 ZJ Grand Cherokee Forum 0 08-11-2002 08:24 AM
