03 CGL 4.7 Cruise Control Not Working - The Lights On But Nobody Home - JeepForum.com
post #1 of 27 Old 03-02-2013, 05:54 PM Thread Starter
webby88
Strange development and forum search did not yield any constructive answers. So here goes:
My 03 GC Limited 4.7 my cruise control stopped working. I turn it on, the dash light comes on, I hit set and the cruise does not engage at all.
To the best of my recollection it worked quite recently (city jeep, not much need for cruise) and this weekend on a 200 mile trip it would not engage, no matter what.
I have not done any diagnostics but from what I have read my (azc) climate control has not been doing anything weird with self switching.
Any ideas what to start checking first? Mind you I am on the road so my capabilities till I get home are severely limited.
'03 Grand Cherokee Limited 4.7 QD - DD
'00 Grand Cherokee Laredo 4.7 QT - Shes Alive!
webby88 is offline
post #2 of 27 Old 03-02-2013, 09:12 PM
jeffthe jerk
2003 WJ
Wj
this happened to me a few times it could be a vac line is off that's what my problem was
jeffthe jerk is offline
post #3 of 27 Old 03-02-2013, 09:20 PM
highjenks
Check all vacuum lines first. A faulty or disconnected vacuum reservoir will keep cruise control from working too. Cruise and defrost require vacuum pressure to work. Also be sure to check the fuse isn't blown.
highjenks is offline
post #4 of 27 Old 03-03-2013, 06:58 AM
james_2k
2003 WJ
x3.
i had knocked a vac line off when changing my throttle body, it caused the cruise not to engage
james_2k is offline
post #5 of 27 Old 03-03-2013, 07:23 AM Thread Starter
webby88
I cant believe I didn't see it, the third hose (closest to the firewall) came off the throttle body and I have no idea how. I have not been under my hood since the last oil change over a month ago.
The hose seems a little too squishy to my taste and maybe that is why it came off. I will consider replacing it or throwing a clamp on it.
Thanks guys for pointing me in the right direction!
webby88 is offline
post #6 of 27 Old 03-03-2013, 08:32 AM
james_2k
2003 WJ
nice one
james_2k is offline
post #7 of 27 Old 03-03-2013, 09:56 AM
jeffthe jerk
2003 WJ
yeah i put a small clamp on mine glad we could help
post #8 of 27 Old 06-19-2014, 06:57 AM
rayliff
2003 WJ
Cruise control will not turn on
If you follow the vacuum lines off the intake there is also a switch block that sits on top of the left front wheel well with a green plastic cap (looks like a stem cap) make sure that's finger tight or you have a vacuum leak and cruise will not turn on.
rayliff is offline
post #9 of 27 Old 06-19-2014, 01:09 PM
rdkendrick
2003 WJ
If you are talking about the vacuum reservoir, it sits behind the passenger headlight, which would be the right side.
Sent from my iPad using Electrons
rdkendrick is offline
post #10 of 27 Old 06-26-2014, 09:03 PM
akoutdoors1
2 different units. Both of mine are good, but still no cruise.
akoutdoors1 is offline
post #11 of 27 Old 06-27-2014, 05:31 PM
rdkendrick
2003 WJ
Then my apologies to RAYLIFF. I didn't know about the other unit.
post #12 of 27 Old 06-27-2014, 07:08 PM
asatxj
asatxj's Avatar
Brake light switch misadjusted? Push brake pedal down with one hand, pull plunger out with other. It will move about 3/4 inch. Let pedal go and it will self adjust. Worth a try. Worked on mine.
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #13 of 27 Old 08-30-2014, 03:51 PM
Skyfox16
Is there a cable that runs from the servo to the throttle body? I have two cables, probably the throttle cable and another one that attach to the throttle body and the one cable is really loose. Would this cause the cruise not to work?
Skyfox16 is offline
post #14 of 27 Old 08-30-2014, 04:12 PM
Thomahawk
The other cable goes to the cruise unit, under your headlight, its Controller by vacum, any vacum leak will F it up, most common
Buildthread
Thomahawk is offline
post #15 of 27 Old 08-30-2014, 08:09 PM
rdkendrick
2003 WJ
I did not check before, but for kicks, I decided to check what it says about Speed Control, in my FSM. It says NOTHING about any other vacuum canister. It only mentions the vacuum reservoir, under the passenger headlight.
