'02 WJ Sun roof plastic broke... - JeepForum.com
post #1 of 5 Old 05-14-2012, 05:47 PM Thread Starter
specia1k
Wj '02 WJ Sun roof plastic broke...
Daughters '02 WJ Sun roof had a plastic piece alomg the passenger edge of the sun roof break. Opens fine, but when you go to close the sun roof, a molded plastic piece on the parimeter of the sun roof opening has broken and gets in the way of the sunroof closing. Acts as a wedge and won't allow the roof to close, unless you hold it down beneith the sun roof. We can hold it down while the sunroof retracts and it will close without issue.
Was thinking about super glueing the two pieces together, then glueing a couple support pieces along the edges for added support.
Molded thin plastic piece about half way back on the passenger side of the sun roof.
Thoughts?
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline
post #2 of 5 Old 05-14-2012, 06:11 PM
qbny94
Same thing happened to me!! I tried to glue that part with epoxy and super glue and it just broke again. My sunroof doesnt close evenly now and it leaks. So i now have duct tape around the seams to stop water from coming in. I think the only option is to replace the sun roof . I cant seem to find that one part anywhere and you'd think they would make that part out of metal its so flimsy and likely to break because its plastic
qbny94 is offline
post #3 of 5 Old 05-15-2012, 08:05 AM
Double E
Double E's Avatar
The replacement part is about $700. Its the entire carrier system that the sunroof slides on. Labor to r/r the headliner will easily be 6 hours if not more.
It can be done with simple tools in your garage and a LOT of patience. A helper doesn't hurt. Take pics before & after, bag/tag parts and don't get too frustrated.
The good part of this is that in the r/r process, you can also reclaim the extra 2-3 inches of sunroof opening that was removed after the 99 model year. Your sunroof will open to full opening of the roof instead of stopping short and limiting the opening size.
There's a caveat to the larger opening, however, (that I can provide info on if requested) but I think it's no big deal.
Word to the rest of you to lube up the sunroof slide tracks as your days of open roof cruising may be numbered and don't even think of using a boneyard unit to save $. That unit has the same amount of wear yours does.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 5 Old 12-13-2012, 08:59 PM
Teflon916
This same thing happend to my sunroof. The plastic scraped the wheatherstripping off my runroof so now it leaks really bad. Going to walmart now to go buy duct tape.
Teflon916 is offline
post #5 of 5 Old 12-14-2012, 12:51 PM
corvettekid82
The wind deflector that pops up on mine broke a while back, not sure if this is the same piece that you're talking about. They have a metal arm on the end and that is right where mine snapped. I just took the deflector out and the sunroof functions fine now. With the lightbar and spare tire on the roof there is already a ton of wind/noise so I cant even tell the differance with the deflector missing.
Mike - 02 WJ Ltd. 4.7 HO, 3" IRO, 32's | 80 Corvette | 01 Z-28 Convertible
http://www.fquick.com/Corvettekid82
corvettekid82 is offline
WJ Sunroof Plastic "halo thingy" broke.... XJH-007 WJ Grand Cherokee Forum 3 07-06-2015 12:17 PM
Can someone measure their roof basket clearence from roof radryan505 WJ Grand Cherokee Forum 0 11-17-2011 04:03 PM
plastic?? MoparMan1990 WJ Grand Cherokee Forum 9 07-27-2011 08:46 PM
Plastic? MikeeN WJ Grand Cherokee Forum 4 05-01-2011 08:25 PM
WJ Roof basket attactment (roof racks) radryan505 WJ Grand Cherokee Forum 25 01-05-2011 01:50 PM
