'02 WJ, Electric Seat Don't Work... Thoughts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > '02 WJ, Electric Seat Don't Work... Thoughts?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-08-2013, 03:07 PM   #1
specia1k
Wj '02 WJ, Electric Seat Don't Work... Thoughts?
Our '02 WJ has bucket front seats that have electric controls on the side of each seat. Unfortunately, not all the switches work. Each seat has three switches, yet if you toggle them up/down, forward/back, they will work one way, but not the other. So my question, does this sound like a motor issue, or switch issue? And if it's a switch, where do I find replacements?
Thanks... Kevin
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 09:40 PM   #2
HOSTED67
Most likely sounds like a switch problem. You will need to remove the switches and backprobe the connector to test for power when the switches are pushed. This need to be done with a voltmeter, not a test light. You will probably find power into the switches and not coming out.
ASE Certified Master Automobile Technician and Master Truck Technician
HOSTED67 is offline   Reply With Quote Quick reply to this message
